Go to Post The way things generally work in cases like this is simple: if you know something, you can't say it. So keep in mind that if someone does say something, it usually means they don't know. - Alan Anderson [more]
Unread 06-01-2015, 01:39
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
LIDAR Sensor has arrived!
Just wanted to share that a new LIDAR (laser radar/rangefinder) is out on the market from "PulsedLight3D" for $90 -- Class I laser so it's FIRST legal. Just arrived today in the mail, and I hooked it up to my Arduino:
Did some initial testing via I2C, seems to be very accurate between ~20cm and 650cm (as far as I could test it tonight without finding a larger room), 0.5 deg beam width
Here's a snapshot of my Serial output with distance in cm (~100 Hz samples averaged and output at 5 Hz), sitting on my desk facing up to the ceiling.
http://pulsedlight3d.com/
We're going to have fun with this!
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 06-01-2015, 02:07
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: LIDAR Sensor has arrived!
We got ours today as well. Similar results to your tests. Very excited about this little guy.
Unread 06-01-2015, 02:42
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Being a geospatial geek, this is TOTALLY COOL!!!!!!!
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 06-01-2015, 08:24
TylerStaudigel's Avatar
TylerStaudigel TylerStaudigel is offline
FRC #0144 (R.O.C.K)
TylerStaudigel is an unknown quantity at this point
This might be a newbie question, but this can be connected to the robo-rio via the I2C and programmed in labview to give us the distance. Right. I haven't done much work dealing with I2C and am not sure what to expect.
Unread 06-01-2015, 14:47
seg9585's Avatar
AKA: Eric
The sensor has 2 output formats: I2C and PWM. I have tested via I2C and it works great. To use PWM, you'd need to create a low-pass filter to smooth the output which could then be read by the roboRio analog input.
I will be coding up a Java Class this week to interface with I2C on the roboRio, which I'd be happy to share.
My FIRST legacy:
Unread 08-01-2015, 00:15
tech2077 tech2077 is offline
AKA: Matthew Skolaut
FRC #3847 (Spectrum 3847)
tech2077 is an unknown quantity at this point
In case anyone is interested, I wrote up a java class for this, you can use the start/stop functions to use the built in updater Timer, or use the update function to only poll distance when needed.
LIDAR.java
Unread 10-01-2015, 22:06
seg9585's Avatar
AKA: Eric
LIDAR.java
tech2077, are you having any luck with this code? When I attempt to run I get zero distance data. Also, the i2c.read() function returned "true" (aborted). I'm passing in Port.kOnBoard and the sensor is plugged into the I2C port on the roboRio
My FIRST legacy:
Unread 11-01-2015, 03:33
Strange, it has worked for me. I've been using the mxp port so far, so I'll test with the on board one.
Unread 11-01-2015, 04:16
Right now it seems that only the MXP port is supported with the LIDAR, I'm still investigating, but using the same power source and code, only the MXP I2C port will return data.
Unread 11-01-2015, 10:20
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Dimensions: 21 X 48.3 X 35.5 mm
• Performance: Range: 0-40m Laser Emitter
• Accuracy: +/- 0.025m
• Power: 5vdc, <100ma
• Acquisition Time: < 0.02 sec
• Rep Rate: 1-100Hz
• Interface: I2C or PWM
•Max Operating Temp.: 70° C
•Eye safe, laser hazard free
Works up to 40 m, + or - 2.5 cm, <20 ms acquisition time.
We have ordered one.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 11-01-2015, 15:16
seg9585's Avatar
AKA: Eric
Ah, thank you! I originally wrote up my own test code without the scheduler implementation and couldn't get it to work in this port, so I switched to yours with similar results. They seem to work just fine in the expansion port, making me curious if the I2C onboard has a bug or is otherwise disabled on the roboRio. I'll contact NI and let them know.
For now, works perfectly on the MXP, thanks again!
My FIRST legacy:
Unread 11-01-2015, 15:39
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I might get one of these to poke around with. Our programming team is talking crazy talk for autonomous, and I don't know that the drive train will have quite the precision they require to squeak in under 15 seconds.
Anyone tried this out on diamond plate? I bet more than my team has felt a twinge of failure with ultrasonics when moving from the lab to the field.
Unread 11-01-2015, 16:08
Poking around the linux side with i2ctools there are definitive read/write errors showing up for the onboard port, so I'll be sure to let them know.
Anything solid and IR opaque should have good data from this sensor. The diamond plate will definitely give good distance readings, but totes and lexan still need to be tested.
Unread 11-01-2015, 18:34
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
LIDAR.java
How do you (or anyone that has gotten this to work) implement this with the main class. I specifically am using the "Getting Started" example.
I tried using it something like this (don't have the exact code in front of me...):
Where variables are declared:
LIDAR myLidar = new LIDAR(port.kOnboard);
then in teleopPeriodic() I did:
myLidar.update();
System.out.println(myLidar.getPID());
However, 0.0 is only ever printed out to the Riolog. (I also tried having the myLidar.start() and myLidar.stop() inside of teleopInit and disabledInit respectively.
Thanks in advance,
DavisC
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 11-01-2015, 20:23
myLidar.update();
Thanks in advance,
DavisC
It's been discovered that the on board I2C port is having communication problems, use the I2C on the MXP port until the issue is resolved.
