Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 06-01-2015, 16:08
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
FRC Blog - Change Is Here
http://www.usfirst.org/roboticsprogr...ange-Is-Coming
I hope everyone had a wonderful Kickoff! We had a great time here in New Hampshire. At the Founder’s Reception, Dean hosted over 600 of his closest friends at his home. And yes, we probably could have squeezed in a few more. Both of New Hampshire’s US Senators showed up to talk about the importance of FIRST and wish us well. The Founder’s Reception webcast had about 3,800 viewers according to the numbers we have now. I think that webcast is going to be a keeper in future years! Also, our local Kickoff here the next day at Southern New Hampshire University was packed with about 800 people in attendance – I saw very few empty seats for the broadcast, and the field, set up in an adjacent gym, was so crowded after the game reveal it was hard to get around. Lots of excitement and animated discussion, it was great to see.
By now, most teams have worked their way through the Recycle Rush rules and seen the several ways in which this game is different. One key difference is that, like many Olympic sports, teams compete on a points basis rather than Win-Loss-Tie. I recognize this is a significant change for our community, as we have grown accustomed to Win-Loss-Tie as the primary means of ranking teams over many years. It can be surprisingly difficult to shift to this new mindset. Even on the GDC, after we had decided we were taking this new approach, we occasionally found ourselves slipping back into WLT thinking, and had to actively work against that.
To help with this mindset change, and to help both teams and spectators understand what the results of matches mean, we’re enhancing the traditional information displayed during play. These are draft graphics, not yet finalized, but I believe we will end up with something very much like these.
The screen that will be displayed when matches are in progress is shown below. Not much has changed on this, and we still are showing each team’s current rank next to their number. We have added a nifty graphic showing if the alliances have earned Coopertition points, though. If the alliances have not earned those points, the handshake graphic will not be displayed. Please note – on this image and all others in this blog, the point values and team numbers are just thrown in as placeholders. The scores are not necessarily realistic. You will note that in this example, teams 2468 and 2789 have a yellow fill, meaning they are coming to the match with a yellow card. Teams 2468 and 2789, we love you, and we’re sure you’re not going to actually get any yellow cards at your events this season! Also, in the images used for playoff rounds below, we display four teams per alliance to show what things will look like if alliances happen to have a fourth team. This will happen occasionally during the regular season, and always at the FIRST Championship!
This next image shows the enhanced match results screen that will be used during qual rounds. Check out the additional information provided. We show the new rank of each team in the match, based on the final score, and whether or not that rank has changed from before the match was played. No longer will you need to go back to the pit display, or pull up an app, to see what that match may have meant to your team. We also show each team’s Qualification Average – called Average Score on these screens to be more helpful to casual spectators – and how that score changed. Note that Qualification Average is likely to change every match, but rank won’t necessarily. Also notice that a final score that helps one team on an alliance may actually cause problems for the other teams. This screen also shows, if Coopertition points were earned, how many were earned.
During playoff rounds, we start to show a traditional leaderboard, as you would see in many sports. Here’s an example of the screen that will be used to show match results during Quarterfinals. Alliances are shown in rank order based on the results of the match just completed. As you know from reading the Tournament section rules, alliances in the top 50% of the ranking at the end the round move on. They are highlighted in green here because they are currently ranked high enough to advance. As you have also figured out by now, results of matches an alliance are not in can still affect their ability to advance. That’s such a key point, I’m going to repeat it and even spend the extra money to put it in italics: results of matches an alliance are not in can still affect their ability to advance. Each alliance is competing against the full field of every other alliance in that round, not just the alliances they happen to be matched against directly. As a final note, you can see that rounds during playoffs are just numbered sequentially, rather than QF1-1, etc, as they have been in prior years.
Here’s the Semifinals version of the screen. Much the same, just with fewer alliances. And, as you also know from the rules, every alliance will play against every other alliance in this field of four.
And lastly, the version of the match results screen that will be used during Finals. As finals matches are Win-Loss-Tie, that’s the information that gets displayed, rather than averages:
If you are interested in handy pdf of all these screens in one document, you can find it here.
Hope your build season is getting off to a great start!
Frank
Unread 06-01-2015, 16:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: FRC Blog - Change Is Here
TexPlosion! You guys already have a yellow card? There isn't even any defense in this game! I think the GDC might be slightly biased against the texas-sized defense you guys can lay down...
Unread 06-01-2015, 16:25
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Yeah, we got a yellow card, but we're ranked 3 with an impossible (or nearly impossible) score!
What I don't understand is how TEXplosion and WildStang only get 207, somehow TEXplosion breaks (we simply don't do that), and the alliance ends up with 1024 instead ...and then fails to advance. I guess we really were scoring 380+ points per match.
Oh, and that Austin vs Houston + 148 final is epic. Though I don't believe the score.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 06-01-2015, 16:29
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
When could this happen not during the FIRST Championship?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 06-01-2015, 16:31
FRC #6357
If a robot breaks and the backup team is pulled in. Previously, that wasn't indicated on FMS, it just swapped the teams. This seems to suggest that if you use a backup team, then they will display all four teams on the alliance.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 06-01-2015, 16:46
Dylan Danzeiser Dylan Danzeiser is offline
Lobster Drive Lover
FRC #0418 (Purple Haze)
Team Role: Student
Dylan Danzeiser is an unknown quantity at this point
Change really is coming if 118 ends up the 4th robot at an unspecified Texas regional.
Also, 148, you are going down!
Unread 06-01-2015, 16:49
CTbiker105's Avatar
CTbiker105 CTbiker105 is offline
People like grapes.
AKA: Griffin
FRC #0195 (Cyber Knights)
CTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond repute
I'd hate to see the day a competition begins its 999th qualification match.
2016|100-16-1|4 banners|4 medals (Galileo winners/Einstein semifinalists)
2015|??-??-??|5 banners|7 medals (CMP Engineering Inspiration winners/Newton finalists)
2014|73-36-0|2 banners|2 medals
2013|50-19-0|1 banner|1 medal
"Was wir für uns selbst tun, stirbt mit uns. Was wir für andere tun, verbleibt und ist unsterblich."
Unread 06-01-2015, 17:05
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Regionals become a week long.
"Welcome to Day 4 of Qualifications!"
2012 - 2015 : 624 CRyptonite
Team Website
Unread 06-01-2015, 17:09
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
I like the displays of the rankings. It's necessary for this kind of game, but even in the past W-L-T system it would have been nice to have. Team members, and especially spectators, didn't have easy access to ranking information. After a match we'd have to run and found a screen displaying it, to know what the result actually meant for us. Looking forward to the instant feedback.
My main question is how the announcers will handle it. It'll be hard to match the punchiness of "and the blue alliance takes the match!" with a summary of ranking changes.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 06-01-2015, 17:10
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
It is nice to see the graphics of what the split of the score is, but it would be really nice to have access to this data for data analysis. I wonder if it would be possible with these changes to get access to this per match score data.
Unread 06-01-2015, 18:12
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Blog introducing the FMS API
no stranger to the working end of a pencil
Unread 06-01-2015, 19:02
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
I like the reference to Olympic sports in this blog post. I hope people realize by the time competitions start that the lack of winning and losing individual matches doesn't make something less of a sport or less competitive.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 06-01-2015, 17:13
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I hope before they get to the final draft they can finally dump the pink and sky blue gradients and the middle and come up with something a lot more uniform.
Unread 06-01-2015, 18:09
philso philso is offline
FRC #2587
I am Okay with an all-Texas Finals though I am not sure I can get that much vacation time. Can you students get that much time off school? Will you students have to play in 2-3 day shifts?
Unread 06-01-2015, 19:14
FRC #0624
We can make it like the Le Mans race and switch out drive teams and pit crews. Scouts can rotate to the pit, pit can drive the robot, and the drive team can sleep in the stands.
Absolutely nothing can go wrong there
Team Website
