Go to Post It's not pink enough, I don't beleive it! :p - Lil' Lavery [more]
Unread 06-01-2015, 18:08
Rick7B Rick7B is offline
FRC #0120
Rick7B is an unknown quantity at this point
Making Your Robot Fit
http://www.youtube.com/watch?v=9sryrCE4mAo
Ok, I was watching this video and @ the end they talk about your robot being able to be 78 in. tall and as long and wide as you want during play. But in transport configuration it has to be 28" wide x 42" long x 78" tall. I' looked at the manual and checked and it does have to be these sizes. But if we can disassemble our robot, how much time do we have to put it back together on the field?
Unread 06-01-2015, 18:12
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Re: Making Your Robot Fit
That would be a good question for the Q&A.
Personally, I think that there will be a maximum of two minutes or something like that, and someone will start a thread about reassembly times and some people will be at around half a second.
5349- the RoboEagles
You wanna have a BAD TIME?
Unread 06-01-2015, 18:37
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
G10 DRIVE TEAMS may not cause significant or repeated delays to the start of a MATCH.
VIOLATION: The offending ROBOT will be DISABLED
DRIVE TEAMS are expected to stage their ROBOTS for a MATCH safely and swiftly. As a guideline, ROBOTS should be configurable in fewer
than sixty (60) seconds. DRIVE TEAM efforts that either intentionally or unintentionally delay the start of a MATCH are not allowed. Examples of
such delays include, but are not limited to:
A. prolonged use of alignment devices such as templates, tape measures, laser pointers, etc. to precisely place and/or align the ROBOT
B. late arrival to the FIELD
C. being indecisive about where/how to position a ROBOT or Yellow TOTE
D. failing to exit the FIELD once the green lights in the ALLIANCE STATIONS have turned off (indicating MATCH ready)
E. charging pneumatic systems, or any other ROBOT maintenance, once on the FIELD
F. prolonged assembly/disassembly of a ROBOT to transform it from its TRANSPORT CONFIGURATION
so about 60 seconds.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 06-01-2015, 18:52
GaryVoshol's Avatar
Cogito ergo arbitro
Blue box on G11:
DRIVE TEAMS are expected to remove ROBOTS from the FIELD after the MATCH safely and swiftly. As a guideline, ROBOTS should be configurable in fewer than sixty (60) seconds. DRIVE TEAM efforts that either intentionally or unintentionally delay the FIELD reset process are not allowed. Examples of such delays include, but are not limited to:
A. prolonged assembly/disassembly of a ROBOT to transform it to its TRANSPORT CONFIGURATION
B. taking an excessive amount of time to exit the field after a MATCH is complete
(since 2004)
