Go to Post When everyone is exactly even, who do you look up to for ideas and inspiration? - artdutra04 [more]
Unread 09-01-2015, 12:10
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
[Ri3D] Team Indiana Powered By AndyMark (And Corn)
On behalf of Team Indiana, we are proud to present our Robot in 3 Days! Hope you enjoy the video!
https://www.youtube.com/watch?v=1Mf662yER3c
Also, follow us on Facebook and Twitter for additional information (Q&A sessions, documentation, explanations, and more):
Facebook: https://www.facebook.com/ri3dindiana
Twitter: https://twitter.com/Ri3DIndiana
Unread 09-01-2015, 12:18
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: [Ri3D] Team Indiana Powered By AndyMark (And Corn)
Great video and great looking robot !
Will you be releasing any details about the design ?
Thank you for showcasing a passive intake on your robot, really simple and reliable (less moving parts to break ! )
I like how the cutout in the frame auto-aligns totes when dropping down the next tote.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 09-01-2015, 13:04
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Love the drop and lock mechanism for grabbing the totes. Good work guys, see you in St Louis.
Unread 09-01-2015, 13:14
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
The intake was a big deviation in our design process as Danny spoke about extensively in one of the videos during the build. We'd initially intended on using an intake mechanism to bring totes into the robot so that we could avoid having to modify the form factor of the drive base. At the point we discovered a separate mechanism would be required to score the totes it was decided that we should change direction as the value added from those two mechanisms would have been very low. There are a couple interesting lessons that come from that decision that teams can take away.
1.) Are we adding complexity to fix a shortcoming of another mechanism? If so maybe we should re-evaluate that original mechanism. (The 2007 season when I was a student on 1741 comes to mind.)
2.) You can (and should) take time to evaluate your design. If a drastic direction change is required, then you should take it. Sticking with a design just for the sake of sticking with a design is often ill advised.
We had intended on adding another passive feature to improve alignment, but due to some delays in getting the lift build and running we couldn't implement them. It is possible, as the design sits, to have a tote improperly aligned. In this case a small amount of rotation is required to correct the situation, but all in all a misalignment doesn't eat up much time.
I believe at current our plan is to release 3Dpdf files of the CAD by the end of the day. As far as questions about components, Danny details those well in the video.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 10-01-2015, 10:40
PurpleInk PurpleInk is offline
Mrs. BoilerMentor
AKA: Betsy Baxter
FRC #1747 (Harrison Boiler Robotics)
PurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant future
I was so excited to finally be able to share this with everyone! Thanks for the positive comments, everyone
FIRST Team 1741 - Student 2005 - 2007
FIRST Team 1741 - Mentor 2007 - 2012
BoilerMentor Asks Me to Join His Alliance
FIRST Team 1747 - Mentor 2012 - Present
Ri3D Team Indiana - 2015 - Present
Unread 10-01-2015, 14:15
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Looks nice, good concept that I can see teams refining into some pretty slick robots.
Yay Indiana.
Unread 12-01-2015, 10:53
DiehardCybercard's Avatar
DiehardCybercard DiehardCybercard is offline
zaba do de da, FIRST
no team (AndyMark)
DiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud of
Hey friends with robots.
This CAD is model that we created during robot in 3 days. It is missing some of the features that were in the final design seen in the reveal video. We still wanted to provide this so you all can take a better look at the details we do have.
Right Click Save-As
Brett Heininger
AndyMark, Inc. Web & Media
Unread 13-01-2015, 17:45
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
Can you provide the original files, in whatever format you desire? I'd like to get a bit of a closer look at the elevator mechanism if that's possible.
Unread 13-01-2015, 18:03
no team (AndyMark)
Sorry Jon, I'm gonna have to decline your request on that . I don't know if all the teams are this way but we don't want to release measurements. We want our Ri3D effort to be an inspiration and a spring board. We wish for teams to improve upon what we've done. With that in mind we had decided not to release measurements so the basic concept cannot be copied. Sorry to let you down on that front. I can see if the engineering team can get a closer view of what we do have, however. (I do recall the view we have ins't very near the lift).
Brett Heininger
Unread 14-01-2015, 08:40
AKA: Jon Stanley
This makes a lot of sense Brett. Mainly what I was planning on doing is hiding the totes at the front, and getting a bit better view of what's going on with the lift assembly (if there's a video you can point me to even that would be great). I certainly wasn't planning on wholesale copying the design!
Unread 14-01-2015, 09:00
no team (AndyMark)
I've got a bug in the engineer's ear. If he gets a moment to send that to me later Ill put it up. The only video we really have of the lift is the reveal video, unfortunately.
Brett Heininger
Unread 14-01-2015, 09:12
FRC #1747
We'd certainly have no problems answering questions you might have about the mechanism. Just leave them here and we'll field them as we are able.
Unread 14-01-2015, 10:28
Mr. B's Avatar
Mr. B Mr. B is offline
FRC #5122 (RobOTies)
Mr. B is an unknown quantity at this point
At the end of the video, the arms lift a can into position. Is the robot as shown able to pick up both totes and cans. Does the lexan offset pieces allow the arms to go over the can or how does the robot get the can
Thanks
Unread 16-01-2015, 14:52
LamboRobo's Avatar
LamboRobo LamboRobo is offline
AKA: Karthik Vishwamitra
FRC #4550 (Something's Bruin)
LamboRobo is an unknown quantity at this point
Are you using the 4-inch wheels that came with the kit of parts? And are you using a west coast drive (with the center wheels lower)? Thanks guys, and good work on that bot!
Unread 16-01-2015, 15:34
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
We just used the standard KOP wheels and chassis in a long configuration. The center wheel is dropped by .140".
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
