Thread Tools |
Rating:
Display Modes |
roboRio Java installer stuck on untarring
Anybody else having this issue?
Specifically the java installer in /wpilib/tools gets stuck on untarring. The progress bar stops moving. I lets it run for more than 30 minutes and no progress is made. |
Re: roboRio Java installer stuck on untarring
Hi
I'm having the exact same problem. It simply gets stuck after connecting. I've looked into this with wireshark and it seems that after acknowledging the roborio, no more packets are sent through the interface. |
I had a similar issue. Power cycling the rRIO fixed the issue for me.
When in doubt cycle power! Or reflash the firmware on the robotRIO. Then Try it.
Hi. I fixed the problem by imaging the roborio.
#7
09/Jan/2015 16:58:08,932- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/jce.jar, putting tar entry is JRE/lib/jce.jar 09/Jan/2015 16:58:08,938- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/jsse.jar, putting tar entry is JRE/lib/jsse.jar 09/Jan/2015 16:58:08,954- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt 09/Jan/2015 16:58:08,954- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/logging.properties, putting tar entry is JRE/lib/logging.properties 09/Jan/2015 16:58:08,955- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/meta-index, putting tar entry is JRE/lib/meta-index 09/Jan/2015 16:58:08,955- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/net.properties, putting tar entry is JRE/lib/net.properties 09/Jan/2015 16:58:08,956- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/resources.jar, putting tar entry is JRE/lib/resources.jar 09/Jan/2015 16:58:08,983- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/rt.jar, putting tar entry is JRE/lib/rt.jar 09/Jan/2015 16:58:09,660- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security, putting tar entry is JRE/lib/security 09/Jan/2015 16:58:09,660- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/blacklist, putting tar entry is JRE/lib/security/blacklist 09/Jan/2015 16:58:09,661- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/cacerts, putting tar entry is JRE/lib/security/cacerts 09/Jan/2015 16:58:09,664- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/java.policy, putting tar entry is JRE/lib/security/java.policy 09/Jan/2015 16:58:09,664- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/java.security, putting tar entry is JRE/lib/security/java.security 09/Jan/2015 16:58:09,665- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/local_policy.jar, putting tar entry is JRE/lib/security/local_policy.jar 09/Jan/2015 16:58:09,666- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/trusted.libraries, putting tar entry is JRE/lib/security/trusted.libraries 09/Jan/2015 16:58:09,666- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/security/US_export_policy.jar, putting tar entry is JRE/lib/security/US_export_policy.jar 09/Jan/2015 16:58:09,666- DeployController: Processing file /Users/a/wpilib/tools/JRE/lib/tzdb.dat, putting tar entry is JRE/lib/tzdb.dat 09/Jan/2015 16:58:09,671- DeployController: Processing file /Users/a/wpilib/tools/JRE/release, putting tar entry is JRE/release 09/Jan/2015 16:58:09,767- DeployController: Failure to send JRE to the roboRio com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?] at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?] at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?] at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?] at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$165/216870574.run(Unknown Source) [java-installer.jar:?] at java.lang.Thread.run(Thread.java:745) [?:1.8.0_25] Caused by: java.net.ConnectException: Connection refused at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_25] at java.net.AbstractPlainSocketImpl.doConnect(Abstrac tPlainSocketImpl.java:345) ~[?:1.8.0_25] at java.net.AbstractPlainSocketImpl.connectToAddress( AbstractPlainSocketImpl.java:206) ~[?:1.8.0_25] at java.net.AbstractPlainSocketImpl.connect(AbstractP lainSocketImpl.java:188) ~[?:1.8.0_25] at java.net.SocksSocketImpl.connect(SocksSocketImpl.j ava:392) ~[?:1.8.0_25] at java.net.Socket.connect(Socket.java:589) ~[?:1.8.0_25] at java.net.Socket.connect(Socket.java:538) ~[?:1.8.0_25] at java.net.Socket.<init>(Socket.java:434) ~[?:1.8.0_25] at java.net.Socket.<init>(Socket.java:211) ~[?:1.8.0_25] at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?] ... 5 more 10/Jan/2015 12:47:19,742- MainApp: Exiting installer from popup |
#8
That looks like the roboRIO is not imaged. Could you try to format it with the ni image tool and then try to install Java again?
#9
I imaged it but I guess I can reset and try it again from the beginning on monday. Will let you know how it goes.
#10
I had the same problem. If imaging does not fix the problem, ensure that you are connected to the roboRIO network. You cannot just use the USB.
#11
Honestly, the entire Java installer seemed fairly problematic. Make sure you're running it as administrator and make sure that your roboRIO is imaged and you should be fine.
#12
What was overly problematic? Is there anything I can change to make it easier to use? |
#13
I had problems with imaging and had to call NI support. They told me to re image it over ethernet and that fixed the issue for some reason. Anybody know why?
#14
I have no idea why. This happened to me as well when I was attempting to install off a flash drive. Once I put the file on my computer instead, it inexplicably worked.
#15
Had the same problem. Doing everything over ethernet and re-imaging the roboRio fixed it.
