Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 09-01-2015, 23:01
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
2338 MXP Breakout Development
The MXPduino is in early development, here's a very, very basic prototype.
Features:
  • on-board ATMEGA328 will be loaded with Arduino bootloader
  • The ADC inputs on the 328 go directly to IOs on the MXP port, including 2 PWM-capable outputs, 2 I2C capable outputs, and 2 analog outs,
  • Access to MXP DIOs 0-11, AIs 0-3, I2C, and UART
  • Access to Arduino DIOs 2-13 and UART
  • 2x4 header allows shared 5V power between the MXP and arduino, and makes it easy to connect/disconnect serial communication between the roboRIO and the ATMEGA328.
  • Holes for secure mounting to the roboRio
Plans for Revision 2:
  • Adjust placement of the interface header, MXP-UART header, and I2C header down into less crowded board space
  • Add access to MXP DIO12, DIO13, AO0, and AO1, and header for Arduino analogs (although the addition of the MXP pins would do the same thing, a separate header that puts all 6 connections close together could be useful.
  • Reduce space inefficiencies, especially at the bottom of the board
EDIT: some of the traces look a little nerfed in the screenshot. Ignore that, it's been fixed since the screenshot was made.
ID:	17794  Click image for larger version
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
