Go to Post Instead of dreading the potential alliance think of ways to impress them so they want you to be part of it! - Koko Ed [more]
Unread 11-01-2015, 16:13
abrightwell abrightwell is offline
Lead Software Engineer
FRC #0342 (Burning Magnetos)
abrightwell is an unknown quantity at this point
RobotDrive Mecanum with CANJaguar
This weekend we found that there is potentially a bug in RobotDrive.java with CANJaguar and Mecanum.
Specifically we found the following:
RobotDrive.java:72
protected boolean m_isCANInitialized = false;//TODO: fix can
RobotDrive.java#mecanumDrive_Cartesian():499
if (m_isCANInitialized) {
    try {
        CANJaguar.updateSyncGroup(syncGroup);
    } catch (CANNotInitializedException e) {
Essentially, m_isCANInitialized is never set to 'true'. Therefore, 'CANJaguar.updateSyncGroup' is never called. Given the "TODO: fix can" note, I'm certain that this was just an oversight prior to releasing the wpilibj for this year. So, assuming the worst being that it will not be fixed/updated, the effective work around for us in our drive system is the following:
private static final SYNC_GROUP = (byte) 0x80;
robotDrive.mecanumDrive_Cartesian(...);
CANJaguar.updateSyncGroup(SYNC_GROUP);
I'm willing to accept that this may not be the correct solution and would be eager to learn if anyone else has experienced this issue or has suggestions/feedback.
Unread 11-01-2015, 16:27
Re: RobotDrive Mecanum with CANJaguar
I wouldn't assume that even though there is a todo that it's on someone's radar to fix. The Screensteps support page gives the location to report bugs. http://wpilib.screenstepslive.com/s/...port-resources
Unread 11-01-2015, 17:24
Agreed and thanks for the link. However, without a TeamForge account (which seems harder to get than one might think) it isn't possible to report bugs. <sigh/> :-/
At any rate, thanks for the feedback.
Unread 11-01-2015, 18:04
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
We see it, we'll have a fix for this in the next release.
Unread 12-01-2015, 15:11
Awesome! Thanks Fred!
