Go to Post ...we are all winners when people come out of this program and strive to make the world a better place. - Patrick Wang [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 11-01-2015, 19:52
Vinh pham 4587 Vinh pham 4587 is offline
FRC #4587 (Jersey Voltage)
Team Role: Electrical
Vinh pham 4587 is an unknown quantity at this point
CAN regulations
I was wondering if your required or not to use yellow and green colored wires for your CAN connection.
Unread 11-01-2015, 20:07
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: CAN regulations
The answer you seek is in the robot rules sections 4.8 or 4.9. Anyway the only color requirements are for power wires. Signal wire can be any color. You should be consistent though.
Unread 12-01-2015, 15:26
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: CAN regulations
Although the colors may not be required, we highly recommend following the green/yellow scheme for the following reasons.
-Makes robot inspection and troubleshooting easier.
-The colors will match what's labeled on the roboRIO CAN connector
-The colors will match what's labeled on the PDP/PCM Weidmuller connectors.
-The colors match the Talon SRX cable harness.
It all adds up to a better CAN bus experience.
Unread 13-01-2015, 00:46
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: CAN regulations
X1000 especially the part about inspection. Make easy for the RI to see what is going on and the RI will be happier. A happy inspector will bend over backwards to help you get into compliance.
It will also make things easier to trouble shoot, if needed and less likely for someone to connect things wrong when a fix is required in the heat of competition.
Unread 14-01-2015, 00:40
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: CAN regulations
I agree with all of the reasons that you site. And I'll add another for us, green/yellow are the school colors. :-)
However, FIRST has not provided a source for the green/yellow twisted pair.
I have been unable to find a source for the green/yellow twisted pair. Can anyone provide a source?
Thanks
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 14-01-2015, 00:47
Cecil's Avatar
Cecil Cecil is online now
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: CAN regulations
AndyMark sells it in 10 feet sections with a nice shield too. The only other place I have found a green/yellow pair was searching for trailer wiring harnesses, but those weren't twisted.
I'm right 90% of the time, so why worry about the other 3%?
Unread 15-01-2015, 11:28
duane's Avatar
Re: CAN regulations
Thanks!
Duane Murphy
Mentor - Software
Unread 15-01-2015, 11:33
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: CAN regulations
Green wire + Yellow wire + Drill = Twisted Green and Yellow Wire
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 15-01-2015, 11:58
Cecil's Avatar
AKA: Alex Hummel
Re: CAN regulations
This is true, but it doesn't help much when the wire I found was bonded together side by side (more specifically, I found this stuff. Seems like a good price if you pull it apart and twist it yourself.)
Unread 15-01-2015, 13:08
Re: CAN regulations
Nice find! I had searched for things like that, but could only find thicker wire than I wanted. It's weird that the 18 gauge wire is more expensive than the 22 gauge, though.
[edit]Looking up the part numbers on the manufacturer's catalog yields a disappointing result: the two-wire cables offered by ASE Supply are either red/black or yellow/brown pairs. The pictures on their web site are not to be trusted.[/edit]
In short lengths, bonded wire can be twisted without difficulty.
Last edited by Alan Anderson : 15-01-2015 at 13:14. Reason: found the Pico catalog
Unread 15-01-2015, 14:35
Cecil's Avatar
AKA: Alex Hummel
Re: CAN regulations
Well that's a disappointment. After I found that, I noticed AndyMark was selling it too, and just added a few to our order. Good catch on that though, I'd have never looked at the actual catalog before ordering it.
