Go to Post SELECT YOUR STRATEGY BEFORE YOUR ROBOT DESIGN. - Kims Robot [more]
Unread 12-01-2015, 18:23
CreativeName55 CreativeName55 is offline
FRC #2729 (Storm Robotics)
CreativeName55 is an unknown quantity at this point
[Solution] Eclipse cannot find build.xml
So, our team was having this problem, and figured others might be, too, so we decided on sharing the solution. If you get an error in your project, along the lines of: C:\Users\{user}\{project_location}\{project_name}\ build.xml:28: Cannot find C:\Users\{user}\{project_location}\{project_name}\ ${wpilib.ant.dir}\build.xml imported from C:\Users\{user}\{project_location}\{project_name}\ build.xml, then there's a very simple solution. Go to File -> New -> Other, find Robot Java Project and select it, name it whatever, it doesn't matter, just not whatever your main project is named, and after the project has been made, delete it. This should resolve your problem on all your projects.
