Thread Tools |
Rating:
Display Modes |
CAN Jaguar Firmware Update Problems
Is anyone else having trouble using BDC-COMM to update the firmware of black jaguars?
Initial connection is fine, and we are able to assign a CAN id without problem, but when we go to update the firmware, it gets about 10% done and freezes, the jaguar light goes off and stays off. We hunted around and found this solution: 1) C:>bdc-comm-107.exe -c N - replace the 'N' with the COM port number you are using 2) # id X - replace 'X' with the ID you had previously set for that Jaguar (factory default is 1) 3) # update black-jag-v109.bin which worked for one of the jaguars. So we repeated the process again in the bdc-comm gui on another jag, assigned id with no problems, tried to update the firmware. It froze again, so we tried the command line approach as above, only this time, the command-line version also froze during firmware update. Any ideas? Is it possible to configure and update the jags through the roborio's browser-based configuration tool? Thanks |
Re: CAN Jaguar Firmware Update Problems
Yes. It's as simple as opening the webdash, finding your Jaguar, and clicking the update firmware button. I'm not sure if the v109 update was tested over BDC Comm during beta. I know we didn't.
The CTRE devices only use the web interface. |
Hopefully we can recreate the first result, though the last time, when it froze in the command-line version, it locked up the cmd window and wouldn't respond to ctrl-c, killall, or taskmanager force quits. Fingers crossed I guess. Quote:
Sorry for the confusion, and thanks for the correction Joe. |
#7
Ok excellent, we will try tonight after verifying there are no problems with our cables or the contacts on the jags.
Does this Recover Firmware flash the new firmware to it as well, or will we have to retry Update Firmware after they are recovered? Thanks for the help! |
#9
It will load the firmware as normal, (hopefully) making it usable again. Are you using a USB to serial adapter? (If you have access to one) try using a computer with a native serial port on it. I have heard reports of some adapters working fine for everything but the update process. (For reference, I have been using a Keyspan USA-19HS for years without problems.)
#10
We are using a USB-serial adapter. If the problems persist we'll give it a go on one of the school's desktops with native serial. Thanks for the tip.
