Go to Post Everyone is wrong! - Chris is me [more]
Unread 14-01-2015, 20:30
DarthCoder DarthCoder is offline
FRC #4309
DarthCoder is an unknown quantity at this point
Accessing the RoboRIO filesystem
So we're trying to figure out how to access the RoboRIO's filesystem, but we can't find any documentation on it. What's the best way to edit files on the RoboRIO? I heard there's FTP and sFTP support, but I can't find any mention of what the url/IP address would be to access it. Also, it has USB ports, so is it possible to mount it as an external hard drive?
Unread 14-01-2015, 20:57
Re: Accessing the RoboRIO filesystem
From your user program, you can use stdio or the same API you would on a desktop. For LV, any file I/O functions should work.
In order to get files to the roboRIO, you can use a utility such as filezilla. The name of the controller is "roboRIO-team.local". The sftp login is admin and no password. For ftp, the login is anonymous with no password. I haven't done that one in awhile, but I'm pretty sure that is the login.
One other way to do this is to use webdav. I won't go into the details, and while it works, the performance has never been that good.
Greg McKaskle
Unread 14-01-2015, 22:11
FRC #4309
Alright! It worked, thanks.
Unread 14-01-2015, 22:45
http://wpilib.screenstepslive.com/s/...99-roborio-ftp
Unread 15-01-2015, 09:28
FRC #4309
Originally Posted by RufflesRidge View Post
THAT'S where it is! Thanks for posting that link I never found that.
