Go to Post Let gravity be your friend. - MrForbes [more]
Thread Tools Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Unread 15-01-2015, 09:20
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
PID programming help
We are reaching out to the CD community for with using the PID Eclipse C++ function for our bot. After spending the entire night with two students and two mentors we learned that the PID function has so many setups and sub functions that without any real examples we just don’t know what to code. So a lot of help would be greatly appreciated.
I can not post any of our code as it just doesn’t work but we will be using a Gyro as the normal input sensor but all we what back from the PID is a variable only as we will be using that variable in another part of our code that is not a motor function.
A sample of all the setup steps and a better explanation of what every thing does would be very helpful in understanding how a PID works.
Many thanks
Unread 15-01-2015, 10:08
Re: PID programming help
While you are waiting for responses, here are some links where you might find useful information:
https://www.google.com/?gws_rd=ssl#q....com+%22PID%22
http://www.ni.com/white-paper/3782/en/
http://www.chiefdelphi.com/forums/sh...45&postcount=6
http://brettbeauregard.com/blog/2011...-introduction/
https://decibel.ni.com/content/servl...20Tutorial.pdf
http://www.controlguru.com/pages/table.html
http://www.inpharmix.com/jps/PID_Con...ms_Robots.html
http://www.chiefdelphi.com/forums/sh...2&postcount=12
http://www.education.rec.ri.cmu.edu/...edmovement.pdf
If you would give some details about what you are seeking to control with PID you will likely get more targeted answers here. For example, you mentioned the gyro. Are you trying to do field-centric control? Or are you trying the correct for drivetrain anomalies to make the bot travel in a straight line? etc.
Unread 15-01-2015, 10:40
FRC #1514
Ether, thank you for all links. We will review the ones that we haven’t looked at yet.
The best application would be very close to your example of correcting a drivetrain to travel in a straight line but we can not have the PID directly feed the device hence the reason we just what the value from the PID. We have yet to find a way to just retrieve the PID correction value.
From a pure teaching point of view, it would be nice to see what the result would be with given input values.
Unread 15-01-2015, 10:46
What kind of drivetrain?
Can you explain why not? What device are you referring to?
Unread 18-01-2015, 10:11
FRC #1514
Hex or co-axial
Given the very nature of the design "device" It would take a novel to explain.
Unread 18-01-2015, 10:24
FRC #1514
To Ether and Ross,
Thank you for the links and information, it helped up to a point but we have found, like many others that our single very precious resource was being used up at an alarming rate. So we have chalk this one up to; yes failure is an option but lets learn from it and move forward. Perhaps after regional’s we might re-visit the task but a “101 Programming a PID function with examples” would sure help.
Just in case, the “precious resource” is TIME. Five weeks is just to short. We lose a week for exams
Post #12 http://www.chiefdelphi.com/forums/sh...hreadid=133100 also has a very nice to help understand what a PID does.
Unread 18-01-2015, 12:37
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Talking Re: PID programming help
Look at the crab speed class in our code from last year. I think it does what you are looking for. Crates a generic class that he PIDController will write to that you can get with something else.
https://github.com/FRCTeam16/TMW2014
Unread 15-01-2015, 22:52
See this thread. http://www.chiefdelphi.com/forums/sh...ight=pidoutput
