can we still use the CPR-360?
As the title says, can we still using this converter http://www.andymark.com/product-p/am-0899.htm ?
Re: can we still use the CPR-360?
It's for take the signal of a sensor from 12 VDC to 5 VDC so it can be detected for the roboRIO, so in ths way we don't have to build a costum circuit
Are you not able to use one of the 12v to 5v ports on the VRM?
No, because that for powering, and I want to use the CPR-360 for signal conditioning
Oh, I see , from what I can see there is nothing against using it for custom circuits in updates/ the manual. I would suggest asking in the Q and A to be sure though.
#7
Based on earlier posts about a 12V sensor, I think the proper solution is a very simple custom circuit: use two resistors to make a voltage divider. Connect the output of the sensor to one end a 1.5 kilohm resistor. Connect the other end of the 1.5k resistor to the roboRIO's signal input pin, and also to one end of a 1 kilohm resistor. Connect the other end of the 1k resistor to the negative pin on the roboRIO's input. When the sensor supplies 12 volts, the roboRIO will see approximately 4.8 volts. |
#8
