Go to Post The minute you get a functioning mechanism start working on a better one - [more]
Unread 16-01-2015, 18:36
inPlaid inPlaid is offline
FRC #2538
inPlaid is an unknown quantity at this point
d-link losing communication
We set up the d-link with the directions set up on the wpilib http://wpilib.screenstepslive.com/s/...o-for-home-use .
But we are having issues with the d-link periodically losing connection while running wirelessly. Power from the voltage regulator module is consistent and the same for power to the roboRio. Has anyone else encountered anything like this?
Unread 16-01-2015, 18:44
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Re: d-link losing communication
Does the radio completely turn off and reboot, or is it just a loss of connection?
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 16-01-2015, 21:38
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Check all the wiring, including to the RIO. And by that, I mean do a tug test. Too many issues come from having a loose wire you don't notice until a slight tug removes it from the socket.
Unread 16-01-2015, 22:14
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
We had a similar issue and found the issue to be on our computer (not the drive station laptop). I'm still not sure what the issue is. For us I think it may be a driver issue, Windows 8 issue, etc.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 18-01-2015, 15:35
FRC #2538
No, the d-link does not turn off, we just see a loss of connection on the driver station for not even a second, things like motor temporarily turn off and on the logs we see power spikes. What is strange is that everything is fine when we are tethered to the d-link. We tried talking to NI people but they thought it was a d-link issue. We tried swapping out routers to one we knew worked but we still lost connection.
Unread 18-01-2015, 15:50
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Is it causing a brownout?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 18-01-2015, 16:07
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
We had this happen with the new d-link. Try going through the Bridge Configuration Utility again and use the instructions for Reset the wireless bridge. Also, make sure that there are not any other d-link routers turned on.
Unread 18-01-2015, 16:21
AKA: Spencer Lanman
Our exact issue as well. What computer are you using?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 19-01-2015, 17:49
Nunez4296's Avatar
Nunez4296 Nunez4296 is offline
Programmer
AKA: Joseph Nuņez
FRC #4296 (Trident Robotics)
Nunez4296 is an unknown quantity at this point
We had the exact same issue, we found out that it was the main breaker sparking. We redid the connections, and everything was working fine. I would recommend checking this.
