Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
Unread 16-01-2015, 21:00
Dentyne_Ice97 Dentyne_Ice97 is offline
FRC #3965
Dentyne_Ice97 is an unknown quantity at this point
Omni Drive train
Can we replace regular wheels with omni wheels in the standard chassis or are there other special parts we need?
Unread 16-01-2015, 21:03
JohnFogarty's Avatar
JohnFogarty JohnFogarty is online now
AKA: @doctorfogarty
Re: Omni Drive train
That depends. If you use 4" omni wheels there is nothing special you will need to do. If you use larger wheels you may need to purchase new belts.
John Fogarty
Unread 16-01-2015, 21:08
FRC #3965
ok I am using the 4" wheels but when I modeled it in Solidworks the middle wheel seemed like it was too big to fit
Unread 16-01-2015, 21:07
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
It depends on what type/size of wheels you are using. If you elaborate what you are intending to use, we can better help you. Our team is using 6" Vex Pro omnis, And no, it isn't a simple swap. Neither are the 6" aluminum ones from AndyMark. I would recommend downloading the STEP file of the kit chassis from AndyMark, and then see how the omni wheels of your choice would fit. Watch our for the rollers intersecting with the belts. You will need to figure out some sort of spacers.
Unread 16-01-2015, 21:33
FRC #3965
we are using the 4"
Unread 16-01-2015, 21:44
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Are you trying to achieve omni-directional motion, or just improve your skid steer turning?
Unread 19-01-2015, 02:03
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I just posted our spacer/adapter here: http://www.thingiverse.com/thing:642155
These adapt the vex wheel pattern to the AM pulleys in the KOP, and space it so the belt clears the wheel. We still needed to adjust the axle spacers to keep the vex wheels from rubbing.
