Go to Post When I'm hiring an intern "Award Winning VRC Notebook" isn't applicable. But "Award winning technical documentation" sure is. - Andrew Schreiber [more]
Unread 17-01-2015, 18:44
JackOfAllTrade5's Avatar
JackOfAllTrade5 JackOfAllTrade5 is offline
Captain
AKA: Austin
FRC #3673 (C.Y.B.O.R.G. SEAGULLS)
JackOfAllTrade5 is an unknown quantity at this point
Mecanum Polar Drive Help
We are attempting using mecanum_Polar drive for our robot this year. According to the WPILib class for Java, it is declared as:
*robotDriveName*.mecanumDrive_Polar(double magnitude, double direction, double rotatation)
The the explanation form the class says that...
- "magnitude" is it's speed
- "direction" determines strafing
- "rotation" is the spin.
However, when actually applied to the roboRIO, things go awry. What actually happens is this:
- "magnitude" is actually spin
- "rotation" is actually speed
- "direction" doesn't transmit anything, or the roboRIO reads "0" and doesn't send code to Talon motor controllers.
Has anyone else experienced or fixed this? Or have we just done something terribly wrong?
Unread 17-01-2015, 18:47
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Mecanum Polar Drive Help
Could you post your code?
Unread 17-01-2015, 19:22
What does your driver interface look like? i.e., how does the driver control each of the 3 degrees of freedom (forward, strafe,rotate)?
Put the bot up on blocks ,then:
a) issue a pure "forward" command and record the direction each of the 4 wheels is spinning
b) issue a pure "strafe right" command and record the direction each of the 4 wheels is spinning
c) issue a pure "rotate clockwise" command and record the direction each of the 4 wheels is spinning
Post your results here.
Unread 18-01-2015, 00:49
SoftwareRachel's Avatar
SoftwareRachel SoftwareRachel is offline
FRC #4505
SoftwareRachel is an unknown quantity at this point
We had a similar problem the other day and the solution was that two of our motors needed to be inverted.
Unread 18-01-2015, 08:38
The procedure I described in post#3 allows you to determine which motors need to be inverted, and whether the PWM cables are going to the wrong ports/motors.
