Thread Tools |
Rating:
Display Modes |
Is this motor legal?
My team has bought this motor from FIRST but we aren't sure if it's legal
Re: Is this motor legal?
It looks just like an Automotive Van Door motor. Do the rules say you can use an Automotive Van Door motor?
I didn't know that FIRST sells motors, do you have the link for where you bought it? |
We don't have the link but we got from FIRST from excess parts
Mr. Forbes is right, this is an automotive van door motor.
If it does not appear in Table 4-1 under rule R18 in the 2015 FRC Manual, then it cannot be used on a robot for Recycle Rush. I don't see it listed there. |
No you didn't miss anything -- I did!
That van door motor (Bosch type CHP, I think) was a KoP item several years ago, and then was not allowed for several years. Glad to see it is back now. Searching old competition info might find the spec data -- also I think maybe Ether or JVN will have it in calculator menus. I recall they went about 50 RPM and developed a little over 25 N-m stall torque, so about 35 Watt peak output. But please check that against the sources mentioned above. Last edited by Richard Wallace : 19-01-2015 at 12:44. Reason: confused about the rating -- I think 4 N-m continuous |
#7
from the interwebs, through a slightly convoluted path that took over a minute to find... Bosch Van Door from 2006 is my guess.
#8
The van door shown is used as a windshield wiper motor. Would that mean it is covered under windshield wiper motor?
#9
That's good news, Jim. The motor is better than I recalled -- should make a good ~60 lbf elevator driver for teams that can get a ~3" diameter sprocket or pulley onto its shaft.
#10
I didn't know about that as a source for parts, thanks for the info!
#11
Checked the game manual; automotive door motor is listed, part numbers are various, and quantity is unlimited. While we're on the topic does anyone know this motor's weight? haven't been able to find exact spects
#12
If you have the motor on hand, just use a scale. If part numbers are various, that means there are various datasheets on every kind of door motor.
#13
That's exactly what we plan on using it for. We have been trying to make a spool to put on the shaft to make a pulley but it's oddly shaped and metric. Last edited by JustbeingJFK : 21-01-2015 at 09:42. |
#14
Just an FYI, the worm gear is pretty efficient (as far a worm gears go), so its actually easy to back drive it.
