Go to Post "Wow, smells like... physics" - Anna B. [more]
Unread 19-01-2015, 15:52
dracowolf's Avatar
dracowolf dracowolf is offline
AKA: adolph jecmenek
FRC #4610 (Bear Tecs)
dracowolf is an unknown quantity at this point
what kind of camera is needed for vision targeting
we are experimenting with vision targeting and would like to know if an axis cam is required or not? we would also like to know if there are example code written in java?
Unread 19-01-2015, 15:59
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: what kind of camera is needed for vision targeting
you can really use any usb camera with the roborio to my understanding. Check out this code as a starter: http://www.chiefdelphi.com/forums/sh...d.php?t=132809
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 19-01-2015, 16:04
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
The Axis camera is not required. You can use any camera that can interface with you're robot and meets the rules. First may provide sample vision code but I'm not positive. I'm sure many teams would be happy to provide you with example code. I'm don't have the code with me right now but I can post the code our team used last year for aiming at the goals later if you would like to give it a look.
Unread 19-01-2015, 16:16
Cameras are a sensor, so need to meet the rules for sensors. You are not required to use an Axis camera.
FIRST Choice contained some Microsoft USB cameras that are also available from most electronics stores. There are some cameras with USB connectors that are not supported, but many are. The features of the camera that you probably care about are ...
Manual or auto focus?
If auto, is it fast, or does it take quite awhile to adapt.
Does the camera have a crisp image?
I saw some ten dollar web cams with a lens that must be from a Cracker Jack box.
Does the camera deal well with both bright scenes and dark scenes?
Does it have manual settings that let you improve its performance?
Is it easy to mount to the robot?
So that it points where you intended and doesn't wiggle/wobble around.
You may not care that much about the camera being super-HD, since processing or transmitting those images will take a lot of bandwidth and time.
LabVIEW contained vision examples at kickoff. The latest update for Java and C++ has them too.
Greg McKaskle
Unread 19-01-2015, 16:30
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
The most recent updates to the java development plugins now include sample vision processing code. If you have the latest updates to your plugins you can create a new project then choose to create a Example robot java project and then after that there are a variety of sample projects given to you including multiple vision processing sample projects.
Unread 19-01-2015, 16:54
dracowolf's Avatar
Originally Posted by Jalerre View Post
The Axis camera is not required. You can use in camera that can interface with you're robot. First may provide sample vision code but I'm not positive. I'm sure many teams would be happy to provide you with example code. I'm don't have the code with me write now but I can post the code our team used last year for aiming at the goals later if you would like to give it a look.
yes please that would be awsome
Unread 19-01-2015, 18:50
Jalerre's Avatar
FRC #4965 (FIRE)
Subsystem:
package edu.wpi.first.wpilibj.templates.subsystems;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.camera.*;
import edu.wpi.first.wpilibj.image.*;
import edu.wpi.first.wpilibj.templates.RobotMap;
import edu.wpi.first.wpilibj.Servo;
 * @author Developer
public class Oculory extends Subsystem {
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
    public static Oculory instance;
    AxisCamera camera;
    Relay lightRing;
    static boolean hasRun = false;
    Servo baseServo;
    Servo camServo;
    //Camera constants used for distance calculation
    final int Y_IMAGE_RES = 240;		//X Image resolution in pixels, should be 120, 240 or 480
    final double VIEW_ANGLE = 49;		//Axis M1013
    final double PI = 3.141592653;
    //Score limits used for target identification
    final int  RECTANGULARITY_LIMIT = 30;
    final int ASPECT_RATIO_LIMIT = 55;
    //Score limits used for hot target determination
    final int TAPE_WIDTH_LIMIT = 50;
    final int  VERTICAL_SCORE_LIMIT = 50;
    final int LR_SCORE_LIMIT = 50;
    //Minimum area of particles to be considered
    final int AREA_MINIMUM = 100;//150;
    //Maximum number of particles to process
    final int MAX_PARTICLES = 8;
    CriteriaCollection cc;      // the criteria for doing the particle filter operation
    //class used to tabulate scores found by NIVision
    public class Scores {
        double rectangularity;
        double aspectRatioVertical;
        double aspectRatioHorizontal;
    //Score report for each target found
    public class TargetReport {
		int verticalIndex;
		int horizontalIndex;
		boolean Hot;
		double totalScore;
		double leftScore;
		double rightScore;
		double tapeWidthScore;
		double verticalScore;
    public static Oculory getInstance()
        if (instance == null)
            instance = new Oculory();
        return instance;
    private Oculory()
        camera = AxisCamera.getInstance("10.49.65.11");
        lightRing = new Relay(RobotMap.lightRing);
        lightRing.setDirection(Relay.Direction.kForward);
        cc = new CriteriaCollection();      // create the criteria for the particle filter
        cc.addCriteria(NIVision.MeasurementType.IMAQ_MT_AREA, AREA_MINIMUM, 65535, false);
        camServo = new Servo(RobotMap.camServo);
        baseServo = new Servo(RobotMap.baseServo);
    public void initDefaultCommand() {
        // Set the default command for a subsystem here.
        //setDefaultCommand(new MySpecialCommand());
    //adapted directly from the example NIVision project
    public boolean getTarget()
        System.out.println("Command\n");
        TargetReport target = new TargetReport();
	int verticalTargets[] = new int[MAX_PARTICLES];
	int horizontalTargets[] = new int[MAX_PARTICLES];
	int verticalTargetCount, horizontalTargetCount;
        try
             * Do the image capture with the camera and apply the algorithm described above. This
             * sample will either get images from the camera or from an image file stored in the top
             * level directory in the flash memory on the cRIO. The file name in this case is "testImage.jpg"
             ColorImage image = camera.getImage();     // comment if using stored images
             //ColorImage image;                           // next 2 lines read image from flash on cRIO
             //image = new RGBImage("/testImage.jpg");		// get the sample image from the cRIO flash
             BinaryImage thresholdImage = image.thresholdHSV(105, 137, 145, 255, 80, 130);   // keep only green objects
             BinaryImage filteredImage = thresholdImage.particleFilter(cc);           // filter out small particles
             if (!hasRun)
                 filteredImage.write("/filteredImage.bmp");
                 thresholdImage.write("/threshold.bmp");
                 hasRun = true;
            //iterate through each particle and score to see if it is a target
            Scores scores[] = new Scores[filteredImage.getNumberParticles()];
            horizontalTargetCount = verticalTargetCount = 0;
            System.out.println("particles = " + filteredImage.getNumberParticles()+"\n");
            if(filteredImage.getNumberParticles() > 0)
                for (int i = 0; i < MAX_PARTICLES && i < filteredImage.getNumberParticles(); i++)
		ParticleAnalysisReport report = filteredImage.getParticleAnalysisReport(i);
                    scores[i] = new Scores();
		//Score each particle on rectangularity and aspect ratio
		scores[i].rectangularity = scoreRectangularity(report);
		scores[i].aspectRatioVertical = scoreAspectRatio(filteredImage, report, i, true);
		scores[i].aspectRatioHorizontal = scoreAspectRatio(filteredImage, report, i, false);
		//Check if the particle is a horizontal target, if not, check if it's a vertical target
		if(scoreCompare(scores[i], false))
                        System.out.println("particle: " + i + "is a Horizontal Target centerX: " + report.center_mass_x + "centerY: " + report.center_mass_y);
                        horizontalTargets[horizontalTargetCount++] = i; //Add particle to target array and increment count
		} else if (scoreCompare(scores[i], true)) {
                        System.out.println("particle: " + i + "is a Vertical Target centerX: " + report.center_mass_x + "centerY: " + report.center_mass_y);
                        verticalTargets[verticalTargetCount++] = i;  //Add particle to target array and increment count
		} else {
                        System.out.println("particle: " + i + "is not a Target centerX: " + report.center_mass_x + "centerY: " + report.center_mass_y);
                        System.out.println("rect: " + scores[i].rectangularity + "ARHoriz: " + scores[i].aspectRatioHorizontal);
                        System.out.println("ARVert: " + scores[i].aspectRatioVertical);
		//Zero out scores and set verticalIndex to first target in case there are no horizontal targets
		target.totalScore = target.leftScore = target.rightScore = target.tapeWidthScore = target.verticalScore = 0;
		target.verticalIndex = verticalTargets[0];
		for (int i = 0; i < verticalTargetCount; i++)
			ParticleAnalysisReport verticalReport = filteredImage.getParticleAnalysisReport(verticalTargets[i]);
			for (int j = 0; j < horizontalTargetCount; j++)
                                ParticleAnalysisReport horizontalReport = filteredImage.getParticleAnalysisReport(horizontalTargets[j]);
                                double horizWidth, horizHeight, vertWidth, leftScore, rightScore, tapeWidthScore, verticalScore, total;
                                //Measure equivalent rectangle sides for use in score calculation
                                horizWidth = NIVision.MeasureParticle(filteredImage.image, horizontalTargets[j], false, NIVision.MeasurementType.IMAQ_MT_EQUIVALENT_RECT_LONG_SIDE);
                                vertWidth = NIVision.MeasureParticle(filteredImage.image, verticalTargets[i], false, NIVision.MeasurementType.IMAQ_MT_EQUIVALENT_RECT_SHORT_SIDE);
                                horizHeight = NIVision.MeasureParticle(filteredImage.image, horizontalTargets[j], false, NIVision.MeasurementType.IMAQ_MT_EQUIVALENT_RECT_SHORT_SIDE);
                                //Determine if the horizontal target is in the expected location to the left of the vertical target
                                leftScore = ratioToScore(1.2*(verticalReport.boundingRectLeft - horizontalReport.center_mass_x)/horizWidth);
                                //Determine if the horizontal target is in the expected location to the right of the  vertical target
                                rightScore = ratioToScore(1.2*(horizontalReport.center_mass_x - verticalReport.boundingRectLeft - verticalReport.boundingRectWidth)/horizWidth);
                                //Determine if the width of the tape on the two targets appears to be the same
                                tapeWidthScore = ratioToScore(vertWidth/horizHeight);
                                //Determine if the vertical location of the horizontal target appears to be correct
                                verticalScore = ratioToScore(1-(verticalReport.boundingRectTop - horizontalReport.center_mass_y)/(4*horizHeight));
                                total = leftScore > rightScore ? leftScore:rightScore;
                                total += tapeWidthScore + verticalScore;
                                //If the target is the best detected so far store the information about it
                                if(total > target.totalScore)
                                        target.horizontalIndex = horizontalTargets[j];
                                        target.verticalIndex = verticalTargets[i];
                                        target.totalScore = total;
                                        target.leftScore = leftScore;
                                        target.rightScore = rightScore;
                                        target.tapeWidthScore = tapeWidthScore;
                                        target.verticalScore = verticalScore;
                            //Determine if the best target is a Hot target
                            target.Hot = hotOrNot(target);
                        System.out.println("Vertical count" + verticalTargetCount);
                        if(verticalTargetCount > 0)
                                //Information about the target is contained in the "target" structure
                                //To get measurement information such as sizes or locations use the
                                //horizontal or vertical index to get the particle report as shown below
                                ParticleAnalysisReport distanceReport = filteredImage.getParticleAnalysisReport(target.verticalIndex);
                                double distance = computeDistance(filteredImage, distanceReport, target.verticalIndex);
                                if(target.Hot)
                                    System.out.println("Hot target located");
                                    System.out.println("Distance: " + distance);
                                else
                                    System.out.println("No hot target present");
                 * all images in Java must be freed after they are used since they are allocated out
                 * of C data structures. Not calling free() will cause the memory to accumulate over
                 * each pass of this loop.
                filteredImage.free();
                thresholdImage.free();
                image.free();
            } catch (AxisCameraException ex) {        // this is needed if the camera.getImage() is called
                ex.printStackTrace();
            } catch (NIVisionException ex) {
        System.out.println("end getTarget\n");
        return target.Hot;
     * Computes the estimated distance to a target using the height of the particle in the image. For more information and graphics
     * showing the math behind this approach see the Vision Processing section of the ScreenStepsLive documentation.
     * @param image The image to use for measuring the particle estimated rectangle
     * @param report The Particle Analysis Report for the particle
     * @param outer True if the particle should be treated as an outer target, false to treat it as a center target
     * @return The estimated distance to the target in Inches.
    private double computeDistance (BinaryImage image, ParticleAnalysisReport report, int particleNumber) throws NIVisionException
            double rectLong, height;
            int targetHeight;
            rectLong = NIVision.MeasureParticle(image.image, particleNumber, false, NIVision.MeasurementType.IMAQ_MT_EQUIVALENT_RECT_LONG_SIDE);
            //using the smaller of the estimated rectangle long side and the bounding rectangle height results in better performance
            //on skewed rectangles
            height = Math.min(report.boundingRectHeight, rectLong);
            targetHeight = 32;
            return Y_IMAGE_RES * targetHeight / (height * 12 * 2 * Math.tan(VIEW_ANGLE*Math.PI/(180*2)));
     * Computes a score (0-100) comparing the aspect ratio to the ideal aspect ratio for the target. This method uses
     * the equivalent rectangle sides to determine aspect ratio as it performs better as the target gets skewed by moving
     * to the left or right. The equivalent rectangle is the rectangle with sides x and y where particle area= x*y
     * and particle perimeter= 2x+2y
     * @param image The image containing the particle to score, needed to perform additional measurements
     * @param report The Particle Analysis Report for the particle, used for the width, height, and particle number
     * @param outer	Indicates whether the particle aspect ratio should be compared to the ratio for the inner target or the outer
     * @return The aspect ratio score (0-100)
    private double scoreAspectRatio(BinaryImage image, ParticleAnalysisReport report, int particleNumber, boolean vertical) throws NIVisionException
        double rectLong, rectShort, aspectRatio, idealAspectRatio;
        rectShort = NIVision.MeasureParticle(image.image, particleNumber, false, NIVision.MeasurementType.IMAQ_MT_EQUIVALENT_RECT_SHORT_SIDE);
        idealAspectRatio = vertical ? (4.0/32) : (23.5/4);	//Vertical reflector 4" wide x 32" tall, horizontal 23.5" wide x 4" tall
        //Divide width by height to measure aspect ratio
        if(report.boundingRectWidth > report.boundingRectHeight)
            //particle is wider than it is tall, divide long by short
            aspectRatio = ratioToScore((rectLong/rectShort)/idealAspectRatio);
        else
            //particle is taller than it is wide, divide short by long
            aspectRatio = ratioToScore((rectShort/rectLong)/idealAspectRatio);
	return aspectRatio;
     * Compares scores to defined limits and returns true if the particle appears to be a target
     * @param scores The structure containing the scores to compare
     * @return True if the particle meets all limits, false otherwise
    private boolean scoreCompare(Scores scores, boolean vertical)
	boolean isTarget = true;
	isTarget &= scores.rectangularity > RECTANGULARITY_LIMIT;
	if(vertical){
            isTarget &= scores.aspectRatioVertical > ASPECT_RATIO_LIMIT;
	} else {
            isTarget &= scores.aspectRatioHorizontal > ASPECT_RATIO_LIMIT;
	return isTarget;
     * Computes a score (0-100) estimating how rectangular the particle is by comparing the area of the particle
     * to the area of the bounding box surrounding it. A perfect rectangle would cover the entire bounding box.
     * @param report The Particle Analysis Report for the particle to score
     * @return The rectangularity score (0-100)
    private double scoreRectangularity(ParticleAnalysisReport report)
        if(report.boundingRectWidth*report.boundingRectHeight !=0)
            return 100*report.particleArea/(report.boundingRectWidth*report.boundingRectHeight);
        else
            return 0;
    * Converts a ratio with ideal value of 1 to a score. The resulting function is piecewise
    * linear going from (0,0) to (1,100) to (2,0) and is 0 for all inputs outside the range 0-2
    double ratioToScore(double ratio)
        return (Math.max(0, Math.min(100*(1-Math.abs(1-ratio)), 100)));
    * Takes in a report on a target and compares the scores to the defined score limits to evaluate
    * if the target is a hot target or not.
    * Returns True if the target is hot. False if it is not.
    private boolean hotOrNot(TargetReport target)
	boolean isHot = true;
	isHot &= target.tapeWidthScore >= TAPE_WIDTH_LIMIT;
	isHot &= target.verticalScore >= VERTICAL_SCORE_LIMIT;
	isHot &= (target.leftScore > LR_SCORE_LIMIT) | (target.rightScore > LR_SCORE_LIMIT);
	return isHot;
    public void setBrightness(int level)
       camera.writeBrightness(level);
    public void setLight(boolean state)
        if (state)
            lightRing.set(Relay.Value.kOn);
        else
            lightRing.set(Relay.Value.kOff);
    public void moveCamera(double angle)
        camServo.set(angle);
    public void moveBase(double angle)
        baseServo.set(angle);
Acquire Target Command:
package edu.wpi.first.wpilibj.templates.commands;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
 * @author Developer
public class AcquireTarget extends CommandBase {
    public boolean targetFound = false;
    double waitTime = 2.0;
    Timer timeout = new Timer();
    public AcquireTarget() {
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
        requires(camera);
    // Called just before this Command runs the first time
    protected void initialize() {
        timeout.reset();
        timeout.start();
        camera.setBrightness(0);
        camera.setLight(true);
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
        SmartDashboard.putString("Target command", "ran");
        targetFound = camera.getTarget();
        SmartDashboard.putBoolean("Target Found", targetFound);
    //Allow the camera 2 seconds to find a target, move on otherwise.
    protected boolean isFinished() {
        if (targetFound || timeout.get() > waitTime)
            return true;
        return false;
    // Called once after isFinished returns true
    protected void end() {
        timeout.stop();
        camera.setBrightness(80);
        camera.setLight(false);
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
I didn't personally write this code; one of my team members did so I can't be of too much help explaining it but if you have a question I can do my best to answer it.
Unread 19-01-2015, 21:53
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
I think this code works on last years robots on the Crio not RobotRio
Unread 20-01-2015, 00:04
Jalerre's Avatar
FRC #4965 (FIRE)
Like I said, this was written last season. The code should still be very similar up front, the under lying libraries have just changed. It's meant to be reference material.
