Go to Post While at kickoff I asked Woodie if there were any concerns about missed shots at the center goal hitting the operators or the controls. He handed me a ball and told me to throw it at him as hard as I could... How many times does an opportunity like that come up? - Barry Bonzack [more]
Unread 19-01-2015, 18:57
Nosemaj-Yort Nosemaj-Yort is offline
FRC #0955
Nosemaj-Yort is an unknown quantity at this point
RIOLog not showing in Views Tab
The RIOLog output box is not opening in Eclipse. About a week ago the RIOLog disappeared, and we were unable to find it in the other views tab. Java 8 is installed as well as the latest FRC Java plugins. So far we have re-installed Eclipse and the Java plugins, any help would be appreciated.
Unread 19-01-2015, 19:07
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Re: RIOLog not showing in Views Tab
Make sure you ONLY have Java 8 installed, else Eclipse could still be running off Java 7.
Do you have any more info about what you did before it "disappeared"? Had you recently updated it and the update deleted it, or did you restart and it was gone? Or was it just you opened up the computer and couldn't find it?
EDIT: Just making sure, you did check under general again to see if it would pop up correct? I would check again to make sure it doesn't just close it when you installed the update. To find it go to
Originally Posted by WPI
Click Window
Hover over Show View
Click Other
Click the arrow to expand General
Click Riolog
Click OK
Thanks,
Zach
Unread 19-01-2015, 21:21
FRC #0955
Java 7 is not installed and the RIOLog does not show up under the general tab.
Unread 19-01-2015, 22:07
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Try this: Go to Help->Installation Details. copy it all to the clipboard and past into notepad so you can search for "java". See if its using java 8 by looking for the correct path to your java installation. Mine has
-vm
C:\Program Files\Java\jre1.8.0_25\bin\server\jvm.dll
You can also add those two lines to eclipse.ini to ensure its using the correct java.
On my personal system, I found java at C:\ProgramData\Oracle\Java\javapath it was put there on 1/2/2015 (the day before kickoff) so it must have gotten there from installing FRC software. Check to see if you have it.
Is this on windows? If so, from a command prompt type "java -version". See if you get the version you expect. If something different look at PATH to see where its finding it.
Brian K
Team 1225 Robotics Mentor
Unread 19-01-2015, 22:36
FRC #0955
We fixed the problem, it turns out Java 7 was still installed we just couldn't find it. We uninstalled it and re-installed eclipse
