Go to Post When I'm asked the question, "What is the most important computer language to learn to prepare me for a programming career?"; my answer is, "Your second one." - Greg McKaskle [more]
Unread 21-01-2015, 16:54
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Simple Pnuematics Program Issue
Okay so I typed up a simple pnuematics program according to examples on WPILib to extend a cylinder for a second and then retract it.
Netbeans says that it "cannot find the symbol" when I say
solenoid1 = new DoubleSolenoid(1, 2);
It is referring to not being able to find the solenoid1
Here is the program:
 * To change this license header, choose License Headers in Project Properties.
 * To change this template file, choose Tools | Templates
 * and open the template in the editor.
package edu.wpi.first.wpilibj.Driver2015.commands;
import edu.wpi.first.wpilibj.DoubleSolenoid;
 * @author FrankyMonez
public class Solenoid1 extends CommandBase {
    public Solenoid1() {
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
        doubleSolenoid = new DoubleSolenoid(1, 2);
        setTimeout(1);
    // Called just before this Command runs the first time
    protected void initialize() {
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
        doubleSolenoid.set(DoubleSolenoid.Value.kForward);
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        return isTimedOut();
    // Called once after isFinished returns true
    protected void end() {
        doubleSolenoid.set(DoubleSolenoid.Value.kReverse);
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
ANY help will be appreciated! THANKS!
Unread 21-01-2015, 16:57
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Simple Pnuematics Program Issue
Are you getting an error saying doubleSolenoid doesn't exist?
Unread 21-01-2015, 17:10
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
You never defined the object doubleSolenoid anywhere. You first used it inside the constructor, and then tried to use it in a method. You need to add the declaration of the object as an instance variable.
Try adding "DoubleSolenoid doubleSolenoid;" between the two lines which begin with public.
