Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 24-01-2015, 09:56
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
clicking from a gearbox
Hi,
I am trying to figure out why our chain driven WCP dual speed gearbox is clicking. I am determined it is the chain or the sprocket. We use 35 chain with Vex pro sprockets. I noticed a bit of wiggle when the sprocket is on the hex axle. Also, when the chain come to the sprocket inside the gearbox, the chain is not aligned central to the sprocket. Any advice how to fix this?
Thanks
Alumni from 75 and 1885
Unread 24-01-2015, 18:07
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Re: clicking from a gearbox
Can you post a picture of where the chain connects to the gearbox?
Unread 24-01-2015, 18:10
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Whenever we've had a clicking sound from our drive, it has almost always been bad bearings or busted hex bearings.
A picture would be very helpful here.
R.C.
MadTown Robotics Team 1323
Unread 24-01-2015, 19:10
DonRotolo's Avatar
Back to humble
FRC #0832
A tiny piece of the chain (e.g., master link) may be protruding and contacting something.
Unread 25-01-2015, 20:47
75vs1885's Avatar
AKA: Stephen
FRC #1885 (Ilite)
I am convinced it a bearing too, I'll see if I can get a pic up within a day or two.
Unread 25-01-2015, 23:19
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
I would check the chains. The master links need a little more room than the rest of it. 35 chain gets a little crowded going through there.
There isn't room for 2 #35 sprockets to be next to each other like in the instructions. pretty sure the chains will touch in that situation.
Unread 26-01-2015, 10:56
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Mschmeh144 is an unknown quantity at this point
Your problem may be that your motors are fighting against each other.
It may also be that the gears inside have somehow popped their key out of the slot, our test bed did this because the constant reversing back and forth and rough handling shook it loose.
Was it clicking before, or did it recently start?
Unread 26-01-2015, 11:37
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
Last year we had a bad bearing that made a clicking noise. Also, it is possible that your chain is not aligned right and a link is jumping a tooth, I would consider this a greater possibility if you are noticing a little shake of the frame with each click.
L.A.S.E.R - Light Amplification by the Stimulated Emission of Radiation
Unread 26-01-2015, 16:39
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these parts
Try using a process of elimination to find where the clicking noise is coming from. First disconnect the chain and run the motor with gears. If the noise has stopped, must be coming from the chain or onward to what ever is connected along with the chain drive.
Second, a long wooden dowel (36 x 1/2") will work wonders at locating noise origins. Hold the dowel up and pressed firmly to your outer ear. By moving the dowel around touching different parts, sounds will increase or decrease depending how close you are to the noise. However you must use some common sense and don't place it between the sprocket and chain or any other place that it can be grabbed.
Unread 28-01-2015, 02:25
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
That should be an easy test - what's the frequency of the clicking? That should actually narrow it down quite a bit. The first stage gear reduction is going to have the highest frequency of clicking if that's where it's occurring, and the chain will have the lowest. Simply knowing how fast the motors are spinning and the frequency of the clicking should bring the investigation down to a certain gear or bearing almost immediately.
