pic: 1736 Robot Casserole's U~Slide Drive
Re: pic: 1736 Robot Casserole's U~Slide Drive
What are the green inserts on the rpborio and where did you get them?
http://wildstang.org/blog/?p=472 |
Yep, Wildstang's Cable Magic. Thanks 111 ![]() |
Great to see it in use!
Please check our blog tomorrow. I will be posting up the CAD files for the small/short version for the analog and relay ports. |
It looked very similar I just couldn't tell if it was the same or not.
#7
What were some of the pros and cons of the chassis, not referring to recycle rush, but as a sort of H drive chassis how did it do? I'm exploring different designs for an H drive chassis and noticed yours and though it would be a quick and easy solution to an H drive
#8
Do you have CAD or pictures of how you accomplished your spring suspension? I was designing an H-drive this summer, and I couldn't find any pictures of such a suspension.
#9
Looks like you're asymmetrically powering only the upper left (in the picture) and the lower right wheel. How's that working out? I've never used omniwheels before - do you have to power all the wheels (like a WCD) or not?
#10
You don't *have* to power every wheel on a drivetrain, but you're wasting tractive force by not doing so. It's a very good idea to do so, particularly when the field isn't flat. |
#11
Omnis being all/not all powered depends on the exact type of drive. If they're in tank configuration, they don't all need power. But if you're doing something funny--say, omni-directional movement--you'll need 'em all powered (in general). And, in general, you want all your wheels that are on the ground powered (unless you specifically don't). |
#12
I see it now. Thanks!
+1. I'm thinking about doing something with omniwheels right now in the preseason, and it'll be great to see some examples of spring suspension. |
#13
1. Easy way to add h-drive to kit. 2. U approach straffed well even with a heavy load of totes on the straffe wheel side on robot. 3. Clearance to cross bump easily 4. Ajustable spring for allowed us to dial in quickly during a regional. Cons: 1. Reduced pushing capability due to spring approach to load center wheel in games of defense. 2. Limited travel of center wheel due to using kit plates for 5th wheel 3. Heavy 4. Needed gyro to help compensate for tendacy to turn during straffing. |
#14
We're doing a similar project, but we're mounting our strafe wheel pneumatically, so we can lift it when we don't need to strafe or when we need to go over an obstruction. Pics to follow. |
#15
I like the pneumatic approach better than adjustable spring. We'd lose a lot of pushing power if we used the spring approach in a year with defense as it took more downforce on the straffe wheel than was originally expected for good straffing performance. I also like how the Robowranglers did their double center wheel in 2014. I we do h-drive again, I'd strongly consider this approach. |
