Thread Tools |
Rating:
Display Modes |
We have been able to build and upload code for the past two weeks. I am uploading\deploying different versions of confirmed working code.
We were able to upload and deploy the same code yesterday night, and have made no changes to roborio configuration since then. Today we saw the WPI plugins for eclipse were updated, we updated two of the four programming computers, and only those computers have the following error: [sshexec] Connecting to roboRIO-2200.local:22 [sshexec] Caught exception: SSH_MSG_DISCONNECT: 2 Too many authentication failures for admin Until a fix has been found, do not update your plugins! |
Re: [WARNING][DO NOT UPDATE WPI PLUGINS] Too many authentication failures for admin
You're having authentication problems. Edit your build.properties file within the USER/wpilib/java/current/ant directory.
Inside the build.properties file there us a username and password entry. By default (I assume) the username is lvuser, with a blank password. We changed that to the correct logon for our admin user, (configurable through the roborio webserver) and everything worked again! Imgur links: Thanks Last edited by Hugo_Klepsch : 27-01-2015 at 17:43. Reason: Adding photos |
So, to clarify, the problem was not with the updated WPILib plugins at all but with the fact that you have modified the user accounts on your roboRIO?
Yep
You should probably change the title of this post then?
#7
The WPI plugins, however were updated, therefore I can only assume the only changed variable is somehow a cause of the breakage. |
#8
Code runs as the lvuser/blank password account
admin should remain as admin/blank password Don't change the account setup. |
#9
Rather then changing the properties file included in the wpilib plugins, a less brittle approach would be to change the build.properties in the project directory to have the username and password you want. |
