What are the limitations to roboRIO modifications?
What are the limitations for modifications we can perform on the roboRIO, so that we stay competition legal?
Some examples include:
Re: What are the limitations to roboRIO modifications?
R45 says the RoboRIO must use image version FRC_2015_v23 and firmware 2.1.0f3
I think the OP was referring to the root cause that led the FRC rule makers to make such a rule. |
It's all about safety and fairness. FRC requires everyone to use the same base software so that the field can control your robot. This way everyone starts autonomous at the same time and such. Also, it gives the field the ability to e-stop the robot that jumps over the guardrail.
The last thing you want is for your robot to be having comm issues, everybody else not having them, and the CSA going "Why did you change X item? It wasn't supposed to be changed." |
#7
The system is open, but has a simple reset. If you modify the roboRIO and see issues, reimage it. This is actually quite a bit easier than what can happen to your DS or programming laptop.
Greg McKaskle |
#9
Quote, please.
#10
Conversely, you are NOT allowed to make any other changes (if you want to stay competition legal). I would regard a different OS as being a change, and an illegal one. Not that I'd know how to spot it, but I'm sure someone would. Note, though, that I'm only commenting on legality, not on ability to do something. |
#11
For installing packages, and recompiling the JDK, I would say both of those are perfectly fine. The JDK does not come with the image, so if doing either of those things was illegal, both the Python and Java implementations would be illegal, and we know that both of those are legal. |
#12
