Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 28-01-2015, 10:28
Chris Mounts's Avatar
Chris Mounts Chris Mounts is offline
FRC #1188 (Oaktown Crewz)
Chris Mounts is an unknown quantity at this point
pic: Front View of 2015 Robot
Unread 28-01-2015, 10:31
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: pic: Front View of 2015 Robot
Great CAD work! Thanks for sharing.
1. Are you running 6:1 reduction on 4" mecanums ?
2. What ratio are you running your lift ?
3. Why run belt/chain on two sides of your lift ? (instead of using a single chain/belt)
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 28-01-2015, 10:33
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
If you look at the back shot picture you can see that it is actually one belt.
Unread 28-01-2015, 11:26
It's one continuous belt wound by two motors. The thought is that it should provide more even lift and help avoid racking.
Lift ratios are 11:72 (CIM to gear) then 18:36 timing pulley to a 4" wheel.
We're at an 11:72 reduction to the 4" wheels. It's to fast. Fingers crossed that we can work something out in code. The alternative of having a second reduction wasn't practical in the design.
Unread 28-01-2015, 11:38
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
What do you find too fast about it? We are running a similar ratio but I love it, what made you determine it was too fast?
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 28-01-2015, 14:20
Wisdom of the crowd and experience. It seems like the target speed for this year is something less than 10 ft/s. This ratio should put us between 11 and 14 ft/s. Not terrible but a little fast. This is why I think our programmers can fix it in code by limiting max power to the motors.
Do you have this setup running? We ordered the wrong CIM gears and are waiting for the correct ones to arrive (hopefully today) before we can test drive it. If you do have it running, how is it going? Is it controllable? Our biggest worry right now keeping the bot from becoming a 120 lb wrecking ball to our partners towers.
Unread 28-01-2015, 17:44
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Yes, ours is running. I love it but I have a lot of drive experience. That will be the main factor, I don't know what your drivers are capable of so that is hard to judge. Remember that decreasing power to motors in code with also decrease the amount of totes you may be able to push...although that shouldn't become a factor.
PM me if you have any questions about it.
-Ronnie
