Go to Post … it’s all good as long as the kids are inspired. - AdamT [more]
Unread 28-01-2015, 12:30
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Remote command failed with exit status 1
Hey, guys!
We've been trying to deploy our Java code to our roboRIO from a MacBook Pro. However, every time we try, it spits out this log and won't complete:
Buildfile: /Users/324876/Documents/workspace/2015 Test/build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory /Users/324876/Documents/workspace/2015 Test/build
   [delete] Deleting directory /Users/324876/Documents/workspace/2015 Test/dist
compile:
    [mkdir] Created dir: /Users/324876/Documents/workspace/2015 Test/build
     [echo] [athena-compile] Compiling src with classpath=/Users/324876/wpilib/java/current/lib/WPILib.jar:/Users/324876/wpilib/java/current/lib/NetworkTables.jar to build
    [javac] Compiling 1 source file to /Users/324876/Documents/workspace/2015 Test/build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: /Users/324876/Documents/workspace/2015 Test/dist
    [mkdir] Created dir: /Users/324876/Documents/workspace/2015 Test/build/jars
     [echo] [athena-jar] Copying jars from /Users/324876/wpilib/java/current/lib/WPILib.jar:/Users/324876/wpilib/java/current/lib/NetworkTables.jar to build/jars.
     [copy] Copying 2 files to /Users/324876/Documents/workspace/2015 Test/build/jars
      [jar] Building jar: /Users/324876/Documents/workspace/2015 Test/dist/FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-4301.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
  [sshexec] Connecting to roboRIO-4301.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
     [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-4301.local:22
      [scp] done.
  [sshexec] cmd : killall netconsole-host
  [sshexec] killall: netconsole-host: no process killed
  [sshexec] Remote command failed with exit status 1
      [scp] done.
      [scp] done.
     [echo] [athena-deploy] Starting program.
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] start-stop-daemon: warning: killing process 1413: No such process
BUILD SUCCESSFUL
Total time: 11 seconds
Could someone please help us figure out what we're doing wrong? Thanks!
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 28-01-2015, 19:57
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Remote command failed with exit status 1
No, it's sucessful. It just couldn't kill the robot code, most likely because it wasn't already running.
Unread 28-01-2015, 20:01
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
To clarify, your code was successfully uploaded to the roboRIO. The error you are seeing was that it tried stop any robot code already running but didn't see any.
Unread 28-01-2015, 21:16
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Why does our driver station still display negative under "robot code," then? Are we having a different problem I don't know about?
Unread 29-01-2015, 07:59
Your code is likely crashing. Are you getting any message in the DS Messages window?
Unread 29-01-2015, 11:08
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
I got the following message in the DS message window:
 ERROR Unhandled exception: edu.wpi.first.wpilibj.tables.TableKeyNotDefinedException: Unkown Table Key: /SmartDashboard/Forward Time at [edu.wpi.first.wpilibj.networktables2.NetworkTableNode.getDouble(NetworkTableNode.java:51), edu.wpi.first.wpilibj.networktables.NetworkTable.getNumber(NetworkTable.java:294), edu.wpi.first.wpilibj.smartdashboard.SmartDashboard.getNumber(SmartDashboard.java:144), org.usfirst.frc.team4301.robot.Robot.disabled(Robot.java:90), edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:126), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:234)]
Here is our code:
 * This is the experimental code for the 2015 robot.  DO NOT USE FOR COMPETITION!
 * All code that is usable will be in  a separate project.
package org.usfirst.frc.team4301.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends SampleRobot {
    RobotDrive chassis;
    Joystick DriverStick;
    Joystick OperatorStick;
    Gyro gyro;
    Talon Lift;
    Talon Winch;
    public Robot() {
        chassis = new RobotDrive(0, 1, 2, 3);
        chassis.setExpiration(0.1);
        DriverStick = new Joystick(0);
        OperatorStick = new Joystick(1);
        gyro = new Gyro(0);
        Lift = new Talon(4);
        Winch = new Talon(5);
     * Drive left & right motors for 2 seconds then stop
    public void autonomous() {
        chassis.setSafetyEnabled(false);
        gyro.reset();
        while (isAutonomous() && isEnabled()) {
        	double ForwardTime = SmartDashboard.getNumber("Forward Time", 1.00);
        	double SidewaysTime = SmartDashboard.getNumber("Sideways Time", 5.00);
        	double rotation = 2.00;
        	if(Timer.getMatchTime() < ForwardTime) {
        		chassis.mecanumDrive_Cartesian(0, 0.5, rotation, gyro.getAngle());  //Drive away from driver Station
        	if(Timer.getMatchTime() < SidewaysTime + ForwardTime && Timer.getMatchTime() > ForwardTime) {
        		chassis.mecanumDrive_Cartesian(1, 0, rotation, gyro.getAngle());
        	// Check if time is less than sideways time and greater than forward time.
        	else {
        		chassis.mecanumDrive_Cartesian(0.0, 0.0, 0.0, gyro.getAngle());
        	SmartDashboard.putNumber("Timer", Timer.getMatchTime());
            SmartDashboard.putNumber("Gyro", gyro.getAngle());
        	Timer.delay(0.005); //wait for a short time so the processor doesn't get mad.
    public void operatorControl() {
        chassis.setSafetyEnabled(true);
        while (isOperatorControl() && isEnabled()) {
        	//set x, y, and z values by squaring and multiplying by speed limiter
        	double x = DriverStick.getX() * Math.abs(DriverStick.getX()) * DriverStick.getThrottle();
        	double y = DriverStick.getY() * Math.abs(DriverStick.getY()) * DriverStick.getThrottle();
        	double z = DriverStick.getZ() * Math.abs(DriverStick.getZ()) * DriverStick.getThrottle();
            chassis.mecanumDrive_Cartesian(x, y, z, gyro.getAngle());
            if(DriverStick.getTrigger() == true) {
            	gyro.reset();
            Lift.set(OperatorStick.getY());
            Timer.delay(0.005);		// wait for a motor update time
     * Runs during test mode
    public void test() {
    public void disabled() {
    	while(isDisabled()) {
    		gyro.reset();
    		chassis.mecanumDrive_Cartesian(0.0, 0.0, 0.0, 0.0);
    		SmartDashboard.getNumber("Forward Time");
    		SmartDashboard.getNumber("Sideways Time");
    		Timer.delay(0.005);
What are we doing wrong?
Unread 30-01-2015, 19:05
This is telling you that your code is crashing on line 90 because the SmartDashboard value you are getting doesn't exist. You can either surround those gets by try/catch, or add a default value like you used other places.
