Go to Post drill holes, that should fix it - E. The Kidd [more]
Unread 28-01-2015, 17:27
swicki's Avatar
swicki swicki is offline
AKA: Gavin
FRC #2152 (S*M*A*S*H)
swicki will become famous soon enough
Labview CAN Help
I was curious as to if anyone here would be willing to answer some of the questions that our new programming team is having while attempting to utilize CAN through Labview. We are also open to Skype if you are willing.
Thanks in advance,
-2152
Unread 28-01-2015, 17:34
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Labview CAN Help
There really isn't such a thing as "CAN Programming" unless you're trying to write a driver for some CAN device you specifically want (by handwriting your own CAN frames).
Using the PCM and PDP is explained in the Labview porting guide.
http://wpilib.screenstepslive.com/s/...e-2014-to-2015
Using Talon SRXs on CAN bus is explained in the Talon SRX Software Reference Manual (google it).
Also it helps to go over the roboRIO Web-based config so you can set device IDs for your CAN devices.
http://wpilib.screenstepslive.com/s/...ribution-panel
Unread 28-01-2015, 17:37
ozrien's Avatar
Omar Zrien
AKA: Omar
I think the best first step would be to report what your seeing and what's not meeting your expectations.
Unread 01-02-2015, 05:50
nicool's Avatar
nicool nicool is offline
AKA: Nicole
nicool is an unknown quantity at this point
Thank you for the resources, they helped quite a bit. We were able to have a mentor help out and we are operational now.
