Go to Post No matter what you do and how well you try to protect them, some people are just out there to be candidates for the Darwin Awards! - Jay H 237 [more]
Unread 28-01-2015, 17:29
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Issue with Mecanum Test Code
I uploaded this code and the second I press Enable for teleop the robot goes crazy and all the motors fire. This program is only made to straffe and go forwards/backwards.
Here it is:
package org.usfirst.frc.team4623.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	public XBox stick = new XBox(0);
	SpeedController frontLeftMotor = new Jaguar(0);
    SpeedController frontRightMotor = new Jaguar(1);
    SpeedController rearLeftMotor = new Jaguar(2);
    SpeedController rearRightMotor = new Jaguar(3);
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
     * This function is run once each time the robot enters autonomous mode
    public void autonomousInit() {
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
     * This function is called once each time the robot enters tele-operated mode
    public void teleopInit(){
     * This function is called periodically during operator control
    public void teleopPeriodic() {
                   mecanumDrive(
                    (XBox.LEFTJOY_X+XBox.LEFTJOY_Y)/2,
                    (XBox.LEFTJOY_Y-XBox.LEFTJOY_X)/2,
                    -(XBox.LEFTJOY_Y-XBox.LEFTJOY_X)/2,
                    -(XBox.LEFTJOY_X+XBox.LEFTJOY_Y)/2);
     * This function is called periodically during test mode
    public void testPeriodic() {
    	LiveWindow.run();
    public void mecanumDrive(double FL, double RL, double FR, double RR)   {
        frontLeftMotor.set(FL);
        rearLeftMotor.set(RL);
        frontRightMotor.set(FR);
        rearRightMotor.set(RR);
It is pulling XBox stuff from this class:
 * @author FrankyMonez
public class XBox extends Joystick{
    public XBox(int port) {
        super(port);
    public static final int
            A_BUTTON = 1,
            B_BUTTON = 2,
            X_BUTTON = 3,
            Y_BUTTON = 4,
            START_BUTTON = 8,
            BACK_BUTTON = 7,
            LS_BUTTON = 9,
            RS_BUTTON = 10,
            RB_BUTTON = 6,
            LB_BUTTON = 5,
            LEFTJOY_Y = 2,
            LEFTJOY_X = 1,
            RIGHTJOY_Y = 5,
            RIGHTJOY_X = 4,
            LEFT_TRIGGER = 3,
            RIGHT_TRIGGER = 3;
    public boolean getButtonA() {
     return getRawButton(A_BUTTON);
    public boolean getButtonB() {
        return getRawButton(B_BUTTON);
    public boolean getButtonX() {
        return getRawButton(X_BUTTON);
    public boolean getButtonY() {
        return getRawButton(Y_BUTTON);
    public boolean getButtonRB() {
        return getRawButton(RB_BUTTON);
    public boolean getButtonLB() {
        return getRawButton(LB_BUTTON);
    public boolean getButtonRS() {
        return getRawButton(RS_BUTTON);
    public boolean getButtonLS() {
        return getRawButton(LS_BUTTON);
    public boolean getButtonStart() {
        return getRawButton(START_BUTTON);
    public boolean getButtonBack() {
        return getRawButton(BACK_BUTTON);
    public double getLeftJoyY() {
        return getRawAxis(LEFTJOY_Y);
    public double getLeftJoyX() {
        return getRawAxis(LEFTJOY_X);
    public double getRightJoyY() {
        return getRawAxis(RIGHTJOY_Y);
    public double getRightJoyX(){
        return getRawAxis(RIGHTJOY_X);
    public double getRightTrigger() {
        return -Math.min(getRawAxis(RIGHT_TRIGGER), 0);
    public double getLeftTrigger() {
        return Math.max(getRawAxis(LEFT_TRIGGER), 0);
THANKS for the help!
Unread 28-01-2015, 20:10
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Re: Issue with Mecanum Test Code
Please look at my post on your other thread. You aren't reading the actual joystick values, but instead you are reading static enums.
Unread 29-01-2015, 10:21
LFRobotics's Avatar
FRC #4623
Okay ill try that ASAP and let you know if it works
Unread 29-01-2015, 11:41
LFRobotics's Avatar
FRC #4623
Okay so I changed it to this:
 * directory.
                   mecanumDrive(
                    (stick.getLeftJoyX()+stick.getLeftJoyY())/2,
                    (stick.getLeftJoyY()-stick.getLeftJoyX())/2,
                    -(stick.getLeftJoyY()-stick.getLeftJoyX())/2,
                    -(stick.getLeftJoyX()+stick.getLeftJoyY())/2);
    	LiveWindow.run();
But now only the Y axis of the left joystick does anything and it only activates two motors. And then the left trigger activates two motors. Im so confused because I never even took the values for the left trigger. Is my mecanum code even right - like will it even ever work. And if not how do I program it to work?
THANKS!
Unread 29-01-2015, 12:54
Joey1939's Avatar
AKA: Joey Holliday
I recommend using the RobotDrive class. It will handle taking joystick inputs and directly changing them into motor outputs.
Unread 29-01-2015, 17:39
LFRobotics's Avatar
FRC #4623
import edu.wpi.first.wpilibj.RobotDrive;
 * directory.
    RobotDrive drive = new RobotDrive(0, 1, 2, 3);
			drive.mecanumDrive_Polar(stick.getLeftJoyY(), stick.getLeftJoyX(), 0);
    	LiveWindow.run();
And now the DriverStation says this:
ERROR Unhandled exception instantiating robot org.usfirst.frc.team4623.robot.Robot edu.wpi.first.wpilibj.util.AllocationException: PWM channel 1 is already allocated at [edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:126), edu.wpi.first.wpilibj.PWM.<init>(PWM.java:145), edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:33), edu.wpi.first.wpilibj.Talon.<init>(Talon.java:49), edu.wpi.first.wpilibj.RobotDrive.<init>(RobotDrive.java:115), org.usfirst.frc.team4623.robot.Robot.<init>(Robot.java:26), sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method), sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62), sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45), java.lang.reflect.Constructor.newInstance(Constructor.java:408), java.lang.Class.newInstance(Class.java:433), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:197)]
I am sooooo confused - neither of my programs work and I have no idea why
Unread 29-01-2015, 18:00
LFRobotics's Avatar
FRC #4623
The other thing is is that we have cartesian but I can't seem to be able to import cartesian in Eclipse
Unread 30-01-2015, 20:40
It would help to describe what you've tried and what the error messages are.
Unread 02-02-2015, 14:46
3786KRRobotics 3786KRRobotics is offline
FRC #3786
3786KRRobotics is an unknown quantity at this point
What is most likely happening is that you are instantiating the SpeedControllers with PWM channels of 0,1,2 and 3 and then RobotDrive is attempting to do the same therefore throwing the exception.
RobotDrive has two constructors. One, which you are currently using in your code, takes in integers for the PWM channels of the motor controllers. The other takes in SpeedController objects for the motor controllers.
Both do so in this order:
frontLeftMotor
rearLeftMotor
frontRightMotor
rearRightMotor
If you want control over the motor controllers elsewhere I recommend passing those into the constructor rather than just the PWM channels
Unread 03-02-2015, 11:24
LFRobotics's Avatar
FRC #4623
Okay I have been working tons on this and put up a new post with new code that should work but doesn't
Unread 29-01-2015, 23:15
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Here it is:
 * directory.
                   mecanumDrive(
    	LiveWindow.run();
        super(port);
            A_BUTTON = 1,
            B_BUTTON = 2,
            X_BUTTON = 3,
            Y_BUTTON = 4,
            START_BUTTON = 8,
            BACK_BUTTON = 7,
            LS_BUTTON = 9,
            RS_BUTTON = 10,
            RB_BUTTON = 6,
            LB_BUTTON = 5,
            LEFTJOY_Y = 2,
            LEFTJOY_X = 1,
            RIGHTJOY_Y = 5,
            RIGHTJOY_X = 4,
            LEFT_TRIGGER = 3,
            RIGHT_TRIGGER = 3;
The wpilibj has a built in class for mecanum under robotDrive.
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
