Go to Post I give props to your programmers and programming mentors. - Sgraff_SRHS06 [more]
Unread 29-01-2015, 12:22
Batterink Batterink is offline
FRC #4519
Batterink is an unknown quantity at this point
pneumatic tubing swelling
http://imgur.com/MLbRg18
We have this piece of tubing going from the compressor to a T-fitting. We noticed last night that it had swollen and had it replaced. The new one has now swollen. Our system isn't going above 115 psi, so I don't think the pressure is an issue.
Does anyone have any ideas, or experience with a similar problem?
Unread 29-01-2015, 12:24
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pneumatic tubing swelling
Could the compressor be getting hot and melting the tubing?
Unread 29-01-2015, 12:26
FRC #4519
I suppose. If the tubing is touching the compressor anywhere it would be on the opposite side of where the heatsink is. I didn't think that part of the compressor got very hot, but I could be wrong.
Unread 29-01-2015, 12:32
Flywheel Police
We used a computer fan to blow air across our compressor last year and it kept it nice and cool all season. Before this it was getting extremely hot.
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Is this tubing being connected directly to the compressor output?
If so, I would recommend adding some metal fittings before the plastic tubing to dissipate heat from the hot air coming out of the compressor. Placing one of the large fans from the KoP next to the compressor will also help.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 29-01-2015, 12:36
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'll confirm the suggestion to add a fan, blowing across the compressor, to solve this problem. The duty cycle of the compressor is only 9%, which means you need to let it cool for eleven times as long as you run it. This time of year, we typically are working on the robot, and testing stuff...running it for five minutes at a time is typical, and doing this will over heat the compressor, unless you add active cooling. It doesn't take much to keep it cool, one of those square fans at least 100mm across should do it.
Unread 29-01-2015, 12:37
Flywheel Police
I was amazed last year at how cool the fan kept it, especially with how hot it was getting prior to adding it. I don't think the compressor ever got hotter than warm to the touch.
Unread 29-01-2015, 12:48
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Not only does the compressor get hot from the friction of the piston but the Ideal Gas Law states that increasing the pressure of a gas increases its temperature. The compressed air from the compressor is actually hotter than ambient. If you run it for a long time it would be conceivable that the tube gets heated by the compressed air to a point where it can no longer withstand its designed working pressure and you see the bubbling that you showed.
A short metal pipe attached to the compressor would help to dissipate this heat.
Or let your system coll a bit in between runs.
EDIT: looks like John beat me to it
Unread 29-01-2015, 12:49
FRC #4519
There are a few metal fitting before the tubing is attached. We'll see about mounting a fan to cool it this evening.
Thanks everyone.
Unread 29-01-2015, 13:54
MrForbes's Avatar
AKA: Jim
Thanks everyone.
You're welcome!
You don't need to attach the fan to the compressor itself. It would be better to mount the fan next to, or over, the compressor so it blows air across the compressor head (the part with cooling fins on it). You can mount the fan several inches away, and it will still work well to keep it cool.
Unread 29-01-2015, 12:50
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Would you mind PM me a picture of how you attacked the fan to the compressor? We are just using zip ties at the moment. The fan keeps the compressor WAY cooler but worried about the zip ties possibly being melted.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 29-01-2015, 12:56
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I would not be concerned about the zip ties melting. A quick Google search shows that most zip ties are made out of Nylon 6-6, which has a melting point of ~500° F. Even if the fan somehow fails, I don't think the compressor will get anywhere near that hot.
Unread 29-01-2015, 13:01
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Lets hope not right? lol. Thank you, will stick with simplicity and stay with the zip ties.
-Ronnie
Unread 05-02-2015, 09:51
Flywheel Police
-Ronnie
Here is a picture of how we mounted the fan last year.
https://drive.google.com/file/d/0B6s...ew?usp=sharing
Unread 05-02-2015, 09:54
MrForbes's Avatar
AKA: Jim
One of our students brought in a COTS computer fan, with a built in mounting bracket, it seems to work ok. We don't have a lot of pneumatics on our robot this year, so it won't be running the compressor often.
