Thread Tools |
Rating:
Display Modes |
How to assemble Vex VersaPlanetary?
We ordered two Vex VersaPlanetary gearboxes, and this being our first time using them are not fully sure how to assemble them. When looking on vex I couldn't find anything that showed how to put it all together.
Re: How to assemble Vex VersaPlanetary?
If you're still having troubles, please give our support team a call at 903-453-0802 during business hours or email prosupport [at] vex [dot] com at any time. We're happy to help and appreciate the feedback! |
While the Versa part of VersaPlanetary can cause some confusion (so many parts left over after you've assembled a complete unit), I cannot sing the praises of those gearboxes loud enough.
I've fallen head over heals for them. Overclocked is using 10 (yes 10) of them on their competition robot and bunches more on prototypes, practice chassis, fall projects, ... I've even made a graphic showing "best practices" (see attached jpg). If you are not using VersaPlanetaries, you are missing out. My favorite thing about them? They let you be "Wrong Late" and survive. Being Wrong Late is the number one killer of FIRST aspirations. If you are 25 lbs over weight (as Overclocked was two weeks ago) and you still have TIME then your dreams are not dead. Time gives the the luxury of going on a diet. However, if you are Wrong Late on weight, often your only option is to start hacking your robot to bits (probably making it much less capable or robust or something good that you wished you still had). Gear Ratios and Motor Selection are two areas where FIRST teams are habitually Wrong Late. They don't discover that they can't lift their robot off the ground or that their arm is too fast to control or that they just cannot take that long to lift a tote or that they need just a little more oomph in that kicker, etc. until they are almost ready to put the robot in a bag. VersaPlanetaries make this a recoverable situation. I don't own stock in Vex or IFI, but every team I'm associated with ends up owning a boat load of VersaPlanetaries. If you're running a FIRST team, you probably should too. Cheers, Dr. Joe Last edited by Joe Johnson : 30-01-2015 at 12:46. |
In the details section on the Versaplanetary website there is an awesome user guide.
#7
#8
Thanks for the links, we had seen those pages already our problem was we weren't sure why they gave so many plates and screws for just 1 stage and the cim adapter.
#9
All the plates are there so you can mount a variety of motors into the versaplanetery, you will need to figure out which one is correct for your motor.
#10
These gearboxes are designed to be versatile (hence their name), because we FRC robot builders often change our minds. Parts that can be re-used in a several different ways allow us more freedom to try other solutions, after we've seen how the first one worked -- or didn't. Keep those extra parts -- you might very well be glad to have them, two or three iterations from now.
