ground isolation on VRM and PCM
Hi,
Yesterday I noticed that the ground is isolated between the input and output terminal of both the VRM and PCM. This means you cannot power a sensor from the VRM, and expect to reliably read the input on the RoboRio. They are on completely isolated grounds. Does anybody know why that is (i.e., was this done on purpose or was it an oversight)? Thanks. |
Re: ground isolation on VRM and PCM
Omar Zrien
AKA: Omar FRC #3539 Team Role: Mentor Join Date: Sep 2006 Rookie Year: 2003 Location: Sterling Heights, MI Posts: 135 The VRM is not isolated. If you measure the voltage difference between the VRM ground and the Rio ground you should find it to be very close to zero . |
Thanks for the reply. Measuring the voltage difference won't actually tell you if the grounds are connected or not - only that the grounds are at about the same voltage reference. Depending on the multimeter that you use, you may actually be shorting the ground together with the probes - which would show not voltage differential. I'm actually looking for a resistance measurement between the input ground connection and any/all output ground connections. Mine are reading in the MOhm range....
Thanks! |
Do you mean megOhm (1,000,000 Ohm) or milliohm (0.001 Ohm) when you write "MOhm"? I can check on our parts when I go to our build site this evening. |
I'm just referring to a simple multimeter design that would effectively place a resistor in parallel with your measurement points. A floating ground would then "ground itself" to the other connected terminal. It isn't a real short.
Mega Ohm |
If you are really seeing megaOhms between the input an output grounds, it would indicate that the VRM and PCM are isolating. With your meter set to read resistance, short the two leads together. Verify that you able to get a reading that is less than a few Ohms. |
#7
You cannot measure the DC resistance between the input ground and output ground, and expect a useful measurement, it will be high-z. The reverse battery protection will not allow this. This is true for both PCM and VRM.
The input ground and output ground of the PCM and VRM are not isolated. Is there a problem that's preventing your robot from functioning? |
#8
#9
When a VRM/PCM is unpowered or reverse battery'ed it disconnects the ground. Its basic reverse battery protection. When you power a VRM/PCM properly the input and out ground is connected.
This is unlikely your problem. If it was then manually commonizing the Rio and VRM ground would fix it. Can you oscilloscope the rx pin on the Rio serial port? See if there is actual bytes on the wire. What's the actual symptom? No data bytes or corrupted data bytes? |
#10
Is there a way to see the circuit that disconnects the ground?
Once I ran power and ground for sensor off the RoboRio, everything worked fine. This was a floating reference issue. |
#11
No voltmeter (DVM or Analog) will short if its used to measure voltage between two points (by plugging the probes into right sockets on meter or turning the knob/dial to V, depending on the meter). Its the ammeter that is used to measure current in a circuit has very very low resistance and will short circuit when used to measure the potential difference between two points.
#12
Si prefixes |
#13
Seeing you mentioned sensor power, I am guessing you are having issues getting sensors to work on the roborio, so may want to give this post a read. . .
http://www.chiefdelphi.com/forums/sh...hreadid=133484 |
