Go to Post If FIRST makes a field invisible to the audience, I will buy every team a dozen Krispy Kremes. - Chris is me [more]
Unread 31-01-2015, 15:05
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
code error at C++
When we run as( the code) to the robrio deploy
We receive an error in the file project
<?xml version="1.0" encoding="UTF-8" ?>
<project name="FRC Deployment" default="deploy">
The following properties can be defined to override system level
settings. These should not be touched unless you know what you're
doing. The primary use is to override the wpilib version when
working with older robots that can't compile with the latest
libraries.
<!-- By default the system version of WPI is used -->
<!-- <property name="version" value=""/> -->
<!-- By default the system team number is used -->
<!-- <property name="team-number" value=""/> -->
<!-- By default the target is set to 10.TE.AM.2 -->
<!-- <property name="target" value=""/> -->
<property file="${user.home}/wpilib/wpilib.properties"/>
<property file="build.properties"/>
<properhttp://http://www.chiefdelphi.com/fo...d=14227346 86
TEAM 1946-Tamra
Unread 02-02-2015, 12:38
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
Re: code error at C++
The error message usually indicates the XML cannot be parsed correctly. If you are not familiar with XML, then note that the symbols are very important. Also, your screenshot shows the sysProps.xml also has an error of some kind. Below is what the build.xml file should look like.
<?xml version="1.0" encoding="UTF-8"?>
libraries.
<property file="${user.home}/wpilib/cpp/${version}/ant/build.properties"/>
<import file="${wpilib.ant.dir}/build.xml"/>
</project>
