Thread Tools |
Rating:
Display Modes |
Jittery Motor
We hooked up a BAG motor using a versaplanetary gearbox at a 7:1 ratio. It is well greased but it doesn't run smoothly on full forward, and runs terribly on full reverse. We have calibrated them. There is a video below. Anyone have any thoughts?
https://www.facebook.com/video.php?v=987754734586315 |
Re: Jittery Motor
One thing we had to do this year is grind off the back of one of the pinion pins that is pressed in, to give it clearance. The pin was interfering with other components, and didn't sound healthy when running. That was a 5:1 gear set, but I would suspect that the same tooling is used to assemble 7:1 gear sets as well.
I would check all the components for other interference locations as well, there are a lot of moving parts that might cause headaches. Other than the minor pin interference, we are very happy with the performance and flexibility of the gearboxes. |
Re: Jittery Motor
It is likely the planetary. Have you removed the motor and tested it by itself to see how the motor runs outside the gearbox? If you can isolate the problem to the gearbox itself, it becomes a lot simpler to solve.
Re: Jittery Motor
What's the code you are running on it? Something I've noticed with code is that it often oscillates between forward and backwards. You can also try hooking it straight up to a battery and see what happens. You can also check out the talon and maybe switch that out.
Re: Jittery Motor
What kind of code are you using that's doing that? The code really shouldn't cause a motor to oscillate between forward and backwards too often, unless it is a PID loop trying to get to the exact position... (Or if your driver is rocking the robot back and forth.) |
Re: Jittery Motor
Check the dowel pins used to hold the planet gears. Each of our 7:1s had a dowel pin that stuck just slightly out of the backside.
#7
Re: Jittery Motor
Did you guys figure out the problem. We have an almost identical issue. Bag motor w/ 90:1 versaplanetary running with the new Victor SP. It worked fine directly hooked to battery but when running through the motor controller it looks and sounds like yours.
#8
Re: Jittery Motor
I'm smelling a possible software issue. What is the code you're using to control this motor?
#9
Re: Jittery Motor
if (joyExtra.getRawButton(4))
liftup();
else
liftstop();
if (joyExtra.getRawButton(2))
liftdown();
else{
liftstop();
