Go to Post FIRST: The hardest thing you'll ever love to do. - Stephen Kowski [more]
Unread 02-02-2015, 15:31
Pike3543's Avatar
Pike3543 Pike3543 is offline
Coder
AKA: Connor
FRC #3543 (C4 Robotics)
Pike3543 is an unknown quantity at this point
Any Code needed for an Encoder Sensor
I'm looking to get a AS5304 working for our bot but I'm not sure if any code is needed and overall how to get a signal from it. Anything important I should know?
Unread 02-02-2015, 15:51
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Any Code needed for an Encoder Sensor
Code will definitely be required. The form is very much dependent on which language you're programming your robot in. For Java or C++, you would extend the Encoder class or the CounterBase class, depending on whether you're interested in measuring speed/RPMs or distance/angle of rotation.
Unread 02-02-2015, 16:04
Pike3543's Avatar
Coder
AKA: Connor
I'm looking for distance and to just overall get some sort of reading from it.
I'm using C++. Is there any example code I could use and customize to do what I want it to.
Unread 02-02-2015, 16:34
The code you want is in WPILib.
http://wpilib.screenstepslive.com/s/...or-other-shaft
Unread 02-02-2015, 21:50
Pike3543's Avatar
Coder
AKA: Connor
Thanks this is very helpful
