Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Unread 03-02-2015, 15:54
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Weird template stuff in eclipse
Hello, I am Lord Supreme Programmer over at Team 1410 and my mentor and I noticed something weird: the templates for the command based robot is wrong. We compared it to the samples from GearsBot and PacGoat and they're different! We had to hand write every file so that they worked correctly. Has anyone else noticed this?
Unread 03-02-2015, 16:28
KPSch KPSch is offline
AKA: Ken Schenke
FRC #1987 (Broncobots)
KPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to all
Re: Weird template stuff in eclipse
Can you be a little more specific? In what way is the template wrong - compiler errors, etc?
Unread 04-02-2015, 16:02
AKA: Isaac
It's just not the way that works. If you look at the template vs. the examples they are set up differently. I am sure that the template will work, just you have to do extra work, which is annoying.
I set up a blank code template with the different set up if you would like to compare the two here is a link:
http://www.chiefdelphi.com/forums/sh...d.php?t=133961
As you can see some of the main differences are that there is no CommandBase.cpp/.h and the commands and subsystems have .h files that are written differently.
