pic: A little teaser from 3571
Re: pic: A little teaser from 3571
That's a very aggressively spaced electronics board. So much so that I have to question why it had to be so compact. That wire routing is certainly beneath the minimum bend radius of 12 AWG wire.
Looks quite nice, but I am always concerned that some of the thicker wires are breaking due to too much bending. We had one robot of the last years that we are about to revive for a fundraising event and it had connecting issues... Took us 3 days to figure out that it was one of the networking cable that was broken due to too much bending with cable ties.
But at least this is a nice overview, the wiring cleanup is always a big challenge! |
Looks good to me.
How water resistant is it? We need to know this for... future endeavors.
I love the organization, So very perfect! That is also an excessive amount of Talons
#7
If you can guess the amount of cims we're using and what type of drive we are using, I will send you a button.
#8
Can anyone say interference? Also, look to the fact that the roborio isn't supposed to be near things that are that powerful. Your talons also are going to get hot. Just a warning from our electrical lead.
#9
Can you clarify what you mean by that?
#10
(this is the Electrical lead): By running the pwm signal wires next to large motor wires that could potentially have upwards of 40 amps through them, you risk electromagnetic interference across the pwm. For this reason we like to run our pwm cables as far away from our power cables as possible, and where they have to come near each other, we cross them at a 90 degree angle. This prevents the magnetic fields on the power cables from interfering with pwm communication.
#11
Oh how much I want to covet this board, hold it, whisper things to it. But sadly there isn't a single label on any of the cables or talons. So sad, a thing of beauty, struck down by such a minor thing like being able to trace wires.
#12
Physics Note: Even if the magnetic field were substantial, routing PWM wires parallel to power wires should not have an appreciable effect on signal, since the magnetic field would only cause a Hall Effect on the signal wires. That is, the magnetic field would not speed up or slow down the electrons, it would just shift the electrons to one side of the wire or the other. Just for fun though, let's calculate the magnetic field created by a 12AWG wire, and see how that magnetic field affects a 22AWG PWM cable next to the power cable. Take: I1 = current in the 12AWG wire I2 = current in the 22AWG wire r1 = radius of 12AWG wire = 1.03mm r2 = radius of 22AWG wire = .32mm d = distance from center of 12AWG to center of 22AWG wire The magnetic field B(r) created by the 12AWG wire at a distance r (r>r2) from the center of the wire will be: B(r) = (mu0)*I1/(2*pi*r) The magnetic field will be perpendicular to the propagation of the electrons, which means the magnetic field will cause the electrons in the 22AWG wire to move either toward or away from the 12AWG wire (This is the Hall Effect). The difference in voltage VH between the near side and the far side of the 22AWG wire will be given as*: VH ~= I2*B(r)/(n*t*e-) Where B(r) is given by the first equation, n is the number density of charge carriers of conducting material, t is the thickness of the 22AWG PWM cable, and e- is the fundamental unit of charge. Combining these equations, and taking mu0 = 4*pi*10^-7 (mks), n=8.49*10^28 m^-3 (copper), t = r2 = .00032m, and e- = 6.02*10^-19 C, gives: VH = (4.6*10^-14*I2*I1/d (mks)) V Plugging in some ridiculously high values for I1 and I2, and a ridiculously low value for d: I1 = 1000A I2 = 10A d= .1mm This yields a potential difference between the near and far side of the PWM cable to be 5*10^-6 V. Which could be measurable if you had a good sensor, but doesn't come anywhere near the 5V** high voltage transmitted by the PWM cable. Please don't route your signal and power wires separately for this reason. *At these small of distances, the magnetic field can not be assumed to be constant over the entire width of the cable, hence the ~ sign. **Source needed Last edited by Caleb Sykes : 05-02-2015 at 22:42. |
#13
| | This is standard practice in industry and is described very thoroughly in literature on Electromagnetic Interference. Quote:
You are correct in thinking that the Hall Effect is insignificant in situations like this. I have never seen any mention of it in any literature on Electromagnetic Interference or in any of the many courses my employers have paid to have me attended on the subject. |
#15
It is quite possible I am in this way over my head and that I really don't understand what is going on. Could you possibly link to a more detailed description of this interference you are describing? Everything I am finding in searching relates to AC circuits. |
