Go to Post Yeah, that's a hardware problem. Definitely something to blame the electricals for. Programmers just work there. - EricH [more]
Unread 07-02-2015, 20:49
Ron Nielsen Ron Nielsen is offline
FRC #2046
Ron Nielsen is an unknown quantity at this point
DIO vs PPM Can NI RoboReo read PPM?
I think I understand the difference between PWM signals and PPM signals, how are PPM signals different from DIO? Is PPM a sub type of DIO? Can the NI RoboReo read PPM signals?
Unread 08-02-2015, 00:45
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: DIO vs PPM Can NI RoboReo read PPM?
Pulse Width Modulation (PWM) is not the same thing as Pulse Position Modulation. As the names imply, PWM varies the width of the pulse to effect a change in a motor. PPM varies the position of a pulse within a periodic frame. Both are examples of digital signals but Digital Input/Output (DIO) is a general form of digital interfaces. The PWM and PPM type signals require internal processing of the DIO signals. This is what the Field Programmable Gate Array (FPGA) does for a living.
As far as I know, PPM is not programmed into the RoboRIO's FPGA.
Unread 08-02-2015, 01:06
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Well, yes, but it isn't going to be easy. Since a PPM signal is just pulses, and the RIO can time pulse lengths and position and such, then there's no reason that it couldn't read and decode a PPM signal, but yeah, you'd have to do it manually.
If you decide to write a class to handle a PPM signal, be sure to share it!
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
