Go to Post po-nos, cancans, and totes ma goats - dubiousSwain [more]
Unread 02-09-2015, 08:53 PM
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
BrighidKHeh is an unknown quantity at this point
"Host cannot connect to subnet"
So I tried to run my code in Netbeans to establish a connection, but I get an error every time saying "WARNING: Host is not on same subnet as robot. May not be able to complete all communications with robot."
In the Driver Station, I have Joysticks and Communications, but I can't figure out how to get code. How do I fix this?
Unread 02-09-2015, 09:13 PM
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Re: "Host cannot connect to subnet"
Switch to Eclipse per the 2015 FRC Control System Setup instructions?
https://wpilib.screenstepslive.com/s...eclipse-c-java
Unread 02-10-2015, 05:07 PM
How can I transfer my Netbeans code to Eclipse? Do we HAVE to use Eclipse this year???? My code has no errors in Netbeans, but is made up of all errors in Eclipse, and I'm not sure why.
Unread 02-10-2015, 10:07 PM
Programming Mentor
AKA: Craig Stelter
I'm not an expert in it, but the control system walkthrough says use eclipse this year. I suspect the back end deploy (the part that finds and talks with the roboRio) was updated in eclipse and the old build mech (ant??) in netbeans may not. We've had no problems using eclipse. If for some reason no wpilib imports are being resolved, try opening an example project first before a robotBuilder project. Or start with IterativeRobot skeleton and add your code, but eclipse/C/C++ is what we were directed to use.
Unread 02-11-2015, 08:38 AM
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
It's both any build scripts, but is eclipse that bad? I have had nothing bad go wrong with it. Eclipse over NetBeans any day, in fact most if not art java developers will tell you that
Unread 02-11-2015, 04:26 PM
So I CAN use Netbeans this season? There is nothing bad about Eclipse, but with 5 days left of the build season, I don't have time to try and figure out Eclipse.
Unread 02-11-2015, 04:45 PM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
There is nothing to figure out with Eclipse. I highly suggest you use Eclipse -- figuring out how to use Netbeans rather than Eclipse will be way more time consuming than just switching to Eclipse. It takes maybe thirty minutes max of time to setup Eclipse -- Eclipse this year is actually easier to use than Netbeans last year, in my opinion.
Unread 02-11-2015, 04:57 PM
I already know how to use Netbeans. I'm not sure how or where to figure out Eclipse based off of an FRC code. All of this year's code that I tried to copy over from Netbeans turned into all errors. I figured it would be easier to go with Netbeans because I have no idea what I'm doing with Eclipse.
Unread 02-11-2015, 07:00 PM
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
When you copied your code to Eclipse, did you have the FRC plugins installed and did you create the correct project type. You are going to have a very hard time if you try to continue using Eclipse.
Unread 02-11-2015, 08:06 PM
Yes, I have all of the FRC Plugins installed, and I'm in the wpilib Robot project. Am I able to use Netbeans instead of Eclipse this season though? I haven't received a solid answer to that question yet.
Unread 02-11-2015, 08:47 PM
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
Theoretically, yes. Practically, no. It would probably take someone with a lot of experience a couple days to make a version that works in NetBeans, and I haven't heard of anyone doing it.
Can you post a screenshot of your Eclipse setup open with an error'd file open?
(You can use a site like imgur to upload screenshots, and if you're using a recent version of Windows, you can use the Snipping Tool to take screenshots.)
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
