Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 10-02-2015, 16:36
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
Initial release of RoboRIO Webdash
This is a helpful debugging utility for the RoboRIO, designed to expose diagnostic data from NetConsole, Network Tables, and
Live Window through an elegant web dashboard, hosted by a dedicated python server on-board the RoboRIO.
Current features include
  • Live Netconsole output
  • Server-side Netconsole monitoring, so you can find error messages after the fact.
  • Read-only Live NetworkTables readout
  • Read-only LiveWindow display
  • Minimal resource usage.
Source code and installation instructions can be found on the Github Repo.
My Github Repositories
Unread 11-02-2015, 01:47
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Initial release of RoboRIO Webdash
You may want to change the way you refer to this since "the web dashboard" is a common way that the primary web server on the roboRIO is referred.
