Go to Post My only question is, Can your robot place tetras and deliver Krispy Kremes to team mentors in autonomous mode? - Rich Kressly [more]
Unread 10-02-2015, 23:04
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Broaching a bevel gear
We are planning an off season design project. It involves using a Bevel box ( http://www.andymark.com/product-p/am-2622.htm ) Unfortunately we need to use 1/2" Hex shafts as both shafts, and this gear box uses 3/8". (There use to be a 1/2 Hex version at Andymark, but it has been discontinued.)
My question is if it would be possible to broach these to 1/2 hex. Or alternatively, find a source for gears that would work with out broaching.
Unread 11-02-2015, 01:29
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Broaching a bevel gear
I don't think you can broach those for 1/2" hex. The gear is physically too small it looks like, but I haven't opened up the step file to check.
McMaster sells 1/2" hex boraches if you need those though.
Are you certain you can't just plug one of those Andymark 22t sprockets on there with the 0.75" hex hub? I forget the name, but the hubs can be swapped out for pretty much any size.
