Go to Post Courtesy and kindness should be the words for the weekend. - IndySam [more]
Unread 14-02-2015, 13:37
VaneRaklan VaneRaklan is offline
FRC #2557 (The SOTABots)
VaneRaklan is an unknown quantity at this point
Gyro Instance
I was wondering if anyone knew a way to take an instance of a gyro. So creating a variable that would hold a single value from the gyro that won't change with the actual movement of the gyro. So if you took he instance and it read 263.453 degrees and you started rotating till the gyro read say 340.231 degrees or something; that variable of instance would still read 263.453.
Any ideas on how to do this or some way of doing something like this? (TBH the answer is probably staring me straight in my face)
Unread 14-02-2015, 13:54
wmarshall11 wmarshall11 is offline
FRC #2399
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
Re: Gyro Instance
double gyroVal = gyro.getAngle()
The value of gyroVal will not change.
Programming Project Manager and Lead Web Developer 2012 - 2014
Mount Olive Robotics Team, FRC 11
Mentor 2015 -
The Fighting Unicorns, FRC 2399
Unread 14-02-2015, 15:12
Re: Gyro Instance
See that's what i thought, but I wasn't sure. Thank you!
