Go to Post GP is an ideal to live by, but not a tool to judge with. - Rich Kressly [more]
Unread 17-02-2015, 13:43
choas500 choas500 is offline
FRC #4640
choas500 is an unknown quantity at this point
Acceleration Curve java help
Hey does anyone know how to program an acceleration curve for cim motors??
Unread 17-02-2015, 14:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Acceleration Curve java help
What are you trying to accomplish?
If you really want to control/limit acceleration, you can set up a PIDController using the motor speed(s) as the system input and the acceleration (from the RoboRIO's built-in accelerometer, for example) as the system output.
Unread 17-02-2015, 15:32
As GeeTwo asked, what is the problem you are trying to solve?
If you are simply wanting to prevent driver "jackrabbit" starts and stops so the totes won't fall off the stack you are carrying, a simple solution would be to add a slew rate limiter to your joystick commands.
Unread 17-02-2015, 17:34
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
I'm assuming you want something like this.
double magnitude = Math.pow(2,(driveStick.getMagnitude())-1;
chassis.mecanumDrive_Polar(magnitude, driveStick.getDirectionDegrees(), driveStick.getRotationDirection());
this should make a pretty decent magnitude:acceleration ratio.
It is an exponential function that increases the speed of the robot when reaching the upper bounds.
You can just edit this so that it works with your drive and controls. Or, if you post the code I will do it for you.
Unread 17-02-2015, 17:45
double magnitude = Math.pow(1.3,driveStick.getMagnitude());
chassis.mecanumDrive_Polar(magnitude, driveStick.getDirectionDegrees(), rotationDirection);
Since the OP has not responded to requests to clarify the nature of the problem he is interested in solving, you might want to qualify your suggestion with an explanation of what problem it is intended to solve... lest he take your suggestion and apply it to a problem different from what you inferred.
You might also caution that your suggestion maps the domain -1..+1 to the range 0.769..1.3
Unread 17-02-2015, 18:54
JacobD's Avatar
AKA: Jacob
Yeah, I wasn't thinking. I fixed that. Also, the domain is [0,1] because you cannot have a negative magnitude. But, that assumes that he is using mecanum drive. If not, another solution will be needed.
Joystick stick1, stick2;
double stick1val,stick2val;
stick1val = Math.pow(stick1.getX(),3);
stick2val = Math.pow(stick2.getY(),3);
chassis.tankDrive(stick1val, stick2val);
That would let you take input with a domain of [-1,1] and use it with tank drive.
Unread 17-02-2015, 19:19
FRC #4640
We are trying to fix the automatic jump the robot gets as soon as you move the joysticks.
Unread 17-02-2015, 19:35
JacobD's Avatar
AKA: Jacob
Can you show us your code right now? Otherwise, tell me the type of drive you are using.
Tank Drive:
Mecanum Drive:
double magnitude = Math.pow(driveStick.getMagnitude(),3);
Unread 17-02-2015, 20:08
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Then the slew limiter Ether suggested is probably your best solution:
Unread 17-02-2015, 22:04
FRC #4640
This is our regular code
package org.usfirst.frc.team4640.robot;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
public class Robot extends SampleRobot {
RobotDrive myRobot; // class that handles basic drive operations
Joystick leftStick; // set to ID 1 in DriverStation
Joystick rightStick; // set to ID 2 in DriverStation
CameraServer server;
public Robot() {
myRobot = new RobotDrive(0, 1);
myRobot.setExpiration(0.1);
leftStick = new Joystick(0);
rightStick = new Joystick(1);
server = CameraServer.getInstance();
server.setQuality(50);
//the camera name (ex "cam0") can be found through the roborio web interface
server.startAutomaticCapture("cam0");
* Runs the motors with tank steering.
public void operatorControl() {
myRobot.setSafetyEnabled(true);
while (isOperatorControl() && isEnabled()) {
myRobot.tankDrive(leftStick, rightStick);
Timer.delay(0.005); // wait for a motor update time
Unread 17-02-2015, 22:27
JacobD's Avatar
AKA: Jacob
    Joystick leftStick = new Joystick(0);  // set to ID 0 in DriverStation
    Joystick rightStick = new Joystick(1); // set to ID 1 in DriverStation
    double leftStickVal,rightStickVal;
    public Robot() {
                leftStickVal = Math.pow(leftStick.getY(),3);
                rightStickVal= Math.pow(rightStick.getY(),3);
        	myRobot.tankDrive(leftStickVal, rightStickVal);
Use this code exactly and your problem should be solved.
Unread 18-02-2015, 01:41
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
For those trying to learn from this thread, the non-whitespace differences between the intitial (21:04) and updated (21:27) code are:
# diff -w initial.txt updated.txt
14,15c14,15
< Joystick leftStick; // set to ID 1 in DriverStation
< Joystick rightStick; // set to ID 2 in DriverStation
16a17
37c38,42
< myRobot.tankDrive(leftStick, rightStick);
Unread 18-02-2015, 23:48
vps vps is offline
FRC #3021 (The Agency)
vps is an unknown quantity at this point
I wanted Can Motor controllers but we ended up using regular one. I was going to use the setVoltageRampRate function, because we are top heavy, but I had to create something else. The acceleration curve by Math.pow(val, x) wasn't good enough for us, where x is an int. Why? because if the joystick slips, we don't want the robot to rapidly accelerate. So, what I do is that I read the "ReachVal" from the joystick, then, read the "CurrentVal" from what I set to the CIMs (CurrentVal is initialized to 0). Then, I take the difference, divide that by 7500 (trial and error lead me to this constant), add that to "CurrentVal", in my drive thread. This results in a smooth drive and we don't topple over even though we are quite top heavy.
Hope that helps!
Unread 19-02-2015, 00:51
Originally Posted by Poseidon1671 View Post
How about using Talon.setVoltageRampRate()? The only downside is it would also slow down deceleration, and I think it only works on CANTalons.
^^Here's the code for the above:
change = joystickAxis - limitedJoystickAxis;
if (change>limit) change = limit;
else if (change<-limit) change = -limit;
limitedJoystickAxis += change;
Exactly.
