Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 17-02-2015, 14:09
schleprock's Avatar
schleprock schleprock is offline
Code Jockey
FRC #4905 (AndromedaOne)
schleprock is an unknown quantity at this point
Question moving parts of robot during robotinit
is it against the rules for the robot to move some parts during the robotinit() method (in java)?
in our case, we need to reset the encoder on the arms of the robot to a known position when the robot first starts up. this entails moving the arms to a limit switch and resetting the encoder.
thanks,
Unread 17-02-2015, 14:11
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: moving parts of robot during robotinit
thanks,
It is not possible to move motors (without altering the current pathways to have some sort of manual override) when the robot is Disabled (not in Teleoperated or Autonomous mode).
I don't have a specific rule, but the definition of Disabled in the rule book makes this illegal:
DISABLED – a state in which a ROBOT has been commanded by the Driver Station to deactivate all outputs.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 17-02-2015, 14:38
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Agreed. Place the part as close to the desired location manually during setup, then make this calibration the first thing in autonomous.
Even better, unless it violates transport configuration or other practical issues, move the part to the proper location just before shutting down.
