Go to Post This reminds me a lot of how millennials are regularly called out for simply being younger and having different perspectives. In the end it's the ones who are calling them out in unprofessional in ways that end up embarrassing themselves and looking uninformed. - Karthik [more]
Unread 17-02-2015, 17:54
polarvortexrobo polarvortexrobo is offline
FRC #5637
polarvortexrobo is an unknown quantity at this point
14 awg wire on motors
Our CIM motors have 14 awg wire coming out.
Does that mean we're stuck with a max of 30A breakers?
or is there some weird exclusion here?
Unread 17-02-2015, 18:04
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: 14 awg wire on motors
There is a weird exclusion. See the text under the table in R38. Use a 40 amp breaker, and #12 wire.
Connect the #12 wire to the Motor Controller.
Connect the wire built into the CIM (regardless of wire gauge) to the motor controller.
Unread 17-02-2015, 18:13
That's the rule. Here's a possible explanation.
Unread 17-02-2015, 18:25
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Keep in mind that if you lengthen the motor wires you still need to use 12ga or larger. I'll be at Northstar but not as an inspector so I'm looking forward to checking out your robot!
Unread 17-02-2015, 18:52
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Internally to our team, we not only follow the gauges specified, but try to keep our runs down to 3 to 5 ft (1 - 1.5m). If we go much longer than that for motor wires, we'll bump to the next larger wire. We aren't as picky on signal-level, though we do a few checks to verify that the switches are reliably noted by the 'RIO. This year, we had originally planned to put our control panel at the highest level that our shortest control person could easily work on. However, for CoG reasons, we had put the battery and every motor as low as possible. The board came down.
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The latter. There's a note under the table in R38.
Wires that are recommended by the device manufacturer or originally attached to legal devices are considered part of the device and by default legal.
