Go to Post Well, there goes my strategy of blowing out the opponent and then committing flagrant safety and sportsmanship violations to keep the margin close :D - Jared Russell [more]
Unread 18-02-2015, 13:17
TarkanAl-Kazily TarkanAl-Kazily is offline
FRC #4915
TarkanAl-Kazily is an unknown quantity at this point
Smart Dashboard Stale buttons
Hi,
We are trying to set up our main driver station with a view that will work for our competitions and are removing extra buttons and debug information that we don't want. However, whenever we delete them from the smart dashboard, they come back! The buttons we remove aren't in OI.java or anywhere else in our code, but they persist. The issue seems to be that we have stale data, and looking through the WPI help page we found this (http://wpilib.screenstepslive.com/s/...smartdashboard) page explaining how to fix it, but it isn't very descriptive. How do you restart both the robot and the smart dashboard at the same time? Does anyone know how to stop these buttons from resetting?
Thanks!
--Tarkan
Unread 18-02-2015, 13:19
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Smart Dashboard Stale buttons
Does it still persist after restarting the computer? We were having that issue, then magically the next meeting the buttons were gone.
Unread 18-02-2015, 13:21
FRC #4915
Thanks for the quick response!
I'm not sure actually. Next week we will be able to get our hands on the driver station and our test robot and we will try restarting the computer and seeing what that does.
Unread 18-02-2015, 13:50
There isn't a provision in the NetworkTables support for a variable to be deleted. Once a client has picked up on a variable's existence, it will keep it around. The protocol will then replicate that variable to the server, and any other clients connected.
To remove a variable completely, all programs using it must be stopped. When they are restarted, only the currently created variables will appear.
Unread 18-02-2015, 15:24
FRC #4915
So when we turn both the robot and the smart dashboard on (no matter which order) it should only recreate the ones that are in the robot?
--Tarkan
Unread 18-02-2015, 15:28
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
--Tarkan
I believe we found that the driver station itself also needs to be restarted, and then things are in synch.
Our habit when things change is to restart the smart dashboard and the driver station after any time when we change robot code that would modify or remove any items displayed on the smart dashboard.
