ERROR Loading Java to RoboRIO
We have 2 RodoRIO's and I had loaded java on one on about 1/18/2015 and it worked fine but now when I try to load it on the other one it does not let me load java. Does anyone know how to get around the Oracle update problem.
Lead Programmer (4076) nfusselman1 |
Re: ERROR Loading Java to RoboRIO
Are both roboRIOs set the same way?
Same team number, user account info has not been changed, JRE installed, etc.? Can you post the error you get? Edit: I thought you meant code, not the JRE. |
Ok I did not know they updated it.
Thanks Lead Programmer (4076) nfusselman1 |
