Go to Post And you wonder why these guys are figuring out where to hang another Chairman's banner. :) - Billfred [more]
Unread 24-02-2015, 20:24
daveshike daveshike is offline
FRC #4655 (State Line Robotics)
daveshike is an unknown quantity at this point
Can't configure WPI_MotorControlOpen.vi for "CAN Talon SRX" motor controller
When we create a WPI_MotorControlOpen.vi in LabVIEW, the motor controller type selection dropdown does not include "CAN Talon SRX" as shown on page 22 of the Talon SRX Software Reference Manual. Any suggestions on what we are missing in order to configure the motor open vi for the CAN Talon SRX?
Thanks!
Unread 24-02-2015, 20:31
Re: Can't configure WPI_MotorControlOpen.vi for "CAN Talon SRX" motor controller
Does yours look anything like this one?
What else seems to be missing? Is the Victor SP missing too?
Have you copied any old code or opened any old projects?
Unread 24-02-2015, 20:37
Ours looks similar, but we only have the following selections: Jaguar, CAN Jaguar, Victor and Talon.
I'm not sure if any of the team members have copied old code into the project.
Unread 24-02-2015, 20:42
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Did you by chance create a project with CRio target instead of a RoboRio target?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 24-02-2015, 21:09
I didn't create the project. Do you know a way to check that we have the correct target?
Unread 24-02-2015, 21:15
jman4747's Avatar
AKA: Josh
Team Role: CAD
Open project the explorer and see my attachments.
Edit: What Mark said too.
ID:	18482  Click image for larger version
#banthebag
#RIBMEATS
#1620
Unread 24-02-2015, 21:27
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Did you uninstall last year's LV before installing this years software? I always wondered what to expect if that was skipped.
"Uninstall Old Versions (Recommended)"...
http://wpilib.screenstepslive.com/s/...5-labview-only
Unread 24-02-2015, 21:47
Thanks, everyone, for your help and advice. We'll continue working on this tomorrow. Hopefully we'll get it all sorted.
Unread 25-02-2015, 07:22
The uninstall doesn't cause this. I have three year's of FRC on my same VM. The conflicts, if any, will be at the library and drivers, not the VIs or EXE.
Greg McKaskle
Unread 25-02-2015, 20:23
Thanks, Mark, Josh, Omar, and Greg. The project was using the wrong API location. We found the needed VIs in the correct API location and used them.
You have last year's vi for some reason.
Unread 24-02-2015, 21:03
Ok. Is there a way to replace last year's vi with the updated one? BTW, when a create a new project from scratch, "CAN Talon SRX" shows up.
Unread 24-02-2015, 21:12
Check to see where the Motor Open is being loaded from.
In the Project Explorer window, click on the Files tab and you should see something like the attached.
Look for any paths out of the LabVIEW 2014 tree structure.
The only two directory trees you should see are the LabVIEW 2014 and the Users -> ... -> Documents -> LabVIEW Data -> your project name
