Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 03-03-2015, 13:05
ironmare ironmare is offline
FRC #5072
ironmare is an unknown quantity at this point
NTP host when setting up M1013 Axis Camera?
Hello all,
I am using the IP Axis program and in the "TCP/IP Advanced Settings" screen. I can change my camera name to "axis-camera", but then when I go to the save at the bottom, it asks for a NTP host address. What do I need to type in there?
Unread 03-03-2015, 14:00
adamm adamm is offline
AKA: Michael Adam
FRC #1671 (The Bird Brains)
adamm is just really niceadamm is just really niceadamm is just really niceadamm is just really niceadamm is just really nice
Re: NTP host when setting up M1013 Axis Camera?
I doubt the field has a Network Time Protocol (NTP) server, so you probably should just make this the same thing as the router. (Or use an official one from the NTP Pool)
The camera uses it to get the current time and set its clock, but it won't matter since there wont be anything serving it on the network.
Michael Adam
Director, Central Valley Robotics
FLL and FLL Jr. Affiliate Partner, Central California (2009-Present)
Member, Central Valley Regional Planning Committee (2012-Present)
Volunteer of the Year, Central Valley Regional (2015)
FRC Control System Advisor (2013-Present)
FRC Scorekeeper (2015-Present)
Mentor, Team 1671 (2009-Present)
Member, Team 1671 (2005-2009)
Unread 03-03-2015, 14:49
Set it to obtain NTP server from DHCP.
