Go to Post If Andy Baker wants 9999 for his new team then who's gonna stop him? - IndySam [more]
Unread 09-03-2015, 12:26
jbernardis jbernardis is offline
FRC #1403
jbernardis is an unknown quantity at this point
Maximum current draw through DIO port
What is the maximum current draw through a DIO port. Our team is planning on adding some LED's for visible signal indicators, and the LED's I have found draw 80ma. Is that too much to drive using 5 volts directly from the roborio DIO port, or would it be better to operate these off of 12 volts via a spike?
Unread 09-03-2015, 12:32
Re: Maximum current draw through DIO port
The 5v rail allows a max of 1a (combined so all other 5v pins are included).
https://decibel.ni.com/content/servl...20Overview.pdf
Unread 09-03-2015, 12:34
mac mac is offline
AKA: Thomas (just give me a crabcake)McCubbin
FRC #0686 (Bovine Intervention/Jagbots)
mac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the rough
Over the years. The few custom circuits I have inspected. Generally come to the input, output side. Not sure what max amp draw is or total draw is. Sounds like you are low enough. Thank You Mentor Mac
Unread 09-03-2015, 12:49
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Page 4 of the RoboRio spec says the DIO lines can sink or source 4 mA. Unless I am missing something, happens often , no, you cannot feed the LED directly off a DIO line.
Output high is 3.3 volts nominal.
Unread 09-03-2015, 13:01
I'd recommend using a Spike for LEDs or a custom circuit that only uses the DIO signal as a control.
Unread 09-03-2015, 13:56
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
AndyMark has a DC/DC converter that will output 5V DC 10A max $18
http://www.andymark.com/product-p/am-3068.htm
Unread 09-03-2015, 14:36
FRC #1403
It's hard to believe that a spike draws that much less than a single LED, but there is enough doubt in my mind that I think it's best to just use a spike. I can size my resistor for 12 volts instead of 5 (or 3.3).
Unread 09-03-2015, 14:51
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Spike Specifications
Specification
Signal Connector:Uses a standard non-shrouded 3-wire cable.
Control Signal:High: 3V min @ 4mA Low: ground (High Max 5-12V current limited to 40 mA.)
Max Switching:20 operations per second no load, 6 operation per minute for rated life at rated load.
Operate Time:5 ms typical
Initial Release Time:2 ms typical
Mechanical Life:10 million operations
Electrical Life:100K operations at 20A, 14VDC, 1mH
The input to the spike is opto-isolated so the RoboRio output does not drive the relay directly. If I were to use a spike, I would drive it off an RoboRio relay output & use a regular spike object (or whatever you call those programing thingies) to program it.
Unread 09-03-2015, 15:31
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
According to Vex, the minimium is 4mA, and is current limited to 40mA.
BTW: I think the spike can switch 5v, so you don't have to switch 12v and step it down as much.
Unread 09-03-2015, 17:35
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The spike has been tested for the relay ports. I don't know if they have been tested for a DIO pin. The specs are different. The NI guys say the RoboRIO IO have been tested by teenagers & is nearly indestructible. But I am superstitious (or maybe I have more efficient teenagers. )
The input voltage for the spike's relay section is 12V nominal. I do not know if it will work at 5v.
Unread 09-03-2015, 19:49
You also have a 5V 2A off from your VRM this year - two of them! one is for your radio, the other one we've hooked up to an LED strip.
Unread 09-03-2015, 20:08
Radio only on the 5v/2A outputs
Originally Posted by R32
R32
The Wireless Bridge power must be supplied by the 5V 2A (“Radio”) output of a Cross the Road Electronics Voltage Regulator
Module (VRM) (P/N: am-2857, 217-4245) and must be the only load connected to those terminals.
Unread 10-03-2015, 01:22
[/font]
Good thing we've got a couple of these then...
Unread 10-03-2015, 08:56
philso philso is offline
FRC #2587
This does not mean one should draw anything close to 40mA from the DIO. The chip used might go into current limit mode to save itself from a potential short circuit but the chip manufacturer will never guarantee "proper operation" under these conditions, i.e. the output voltage is unknown.
Unread 10-03-2015, 11:37
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Unless there's something in the 2015 rules I missed, the Pneumatics Control Module is another option for LED control.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
