Go to Post I want to understand the physics. - Molten [more]
Unread 15-03-2015, 14:46
NYNY Match Results data incomplete
Has anyone seen an annoucement explaining why the NYNY Match Results are incomplete?
Name:	NYNY Qual Match Results.png
ID:	18656  Click image for larger version
Name:	NYNY Ranking.png
Unread 15-03-2015, 21:01
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: NYNY Match Results data incomplete
See this post:
Originally Posted by plnyyanks View Post
The field had a really slow internet connection. I'd guess the Javits Center charged an arm and a leg for anything better. Most of the match results uploads are pretty big (they include some log data), so they failed often due to the slow speeds. The rankings uploads are much smaller, that's why they were going through regularly. I know that it seemed to work here and there, which is why the results came in chunks. Not much we could've done, sorry.
All the data should be up now, though
Unread 16-03-2015, 11:02
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liason
AKA: Ryan
FRC #1902 (Exploding Bacon)
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
Slightly off topic, but it appears the rankings for GSCE are incomplete too. The ranking stats only reflect the first 2-1 matches of each robot, while in reality each robot should have data from 11 qualifiers total. (Ranking section of http://www.thebluealliance.com/event/2015gape)
Unread 16-03-2015, 15:06
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
I'm not sure about the blue alliance, but they appear to be correct on the FIRST website?
http://frc-events.usfirst.org/2015/GAPE/rankings
Assuming that they played 11 matches at that event, not 12.
Unread 16-03-2015, 16:36
Oromus's Avatar
AKA: Ryan
The page TBA links to (where it says "Data from FIRST's event page") has the correct information, but TBA itself does not (at least when ranking stats are concerned). FIRST has all the information, but TBA doesn't seem to be using all of it.
Unread 16-03-2015, 19:13
plnyyanks's Avatar
AKA: Phil Lopreiato
FIRST probably manually updated the data after TBA stopped scraping it. We can do a resync the event data from them, which should fix any issues you see
